BT.com
Wishlist
Gigabyte GeForce GTX 750 Ti 1033MHz 2GB PCI-E 3.0 HDMI OC
Delivery
Standard Due date unavailable
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
Gigabyte GV-N75TOC-2GL - graphics card - GF GTX 750 Ti - 2 GB
Graphics card - low profile
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 750 Ti
2 GB GDDR5
Core Clock
1033 MHz
Boost Clock
1111 MHz
Effective Memory Clock
5.4 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
DVI-I (dual link) , DisplayPort , 2 x HDMI
API Supported
DirectX 11.2, OpenGL 4.4
4.2 cm x 17.5 cm x 12.1 cm
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1033 MHz
Boost Clock
1111 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
Nvidia PhysX-Ready, Ultra Durable 2, Nvidia 3D Vision technology, Gold plated HDMI, Adaptive V-Sync, NVIDIA GPU Boost, OC Guru II
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5.4 GHz
Bus Width
128-bit
Required Power Supply
400 W
Low-profile bracket
Software Included
OC Guru ll
4.2 cm
17.5 cm
12.1 cm
Scroll to top
