BT.com
Wishlist
Gigabyte GeForce GTX 670 980MHz 4GB PCI-Express 3.0 HDMI OC
Delivery
Standard Due date unavailable
During October 2013 Claim Batman Arkham Origins + Splinter Cell Blacklist on this Graphics Card via duncsdeals@dabs.com
Gigabyte features the WINDFORCE 3X cooling solution with "Triangle Cool" technology to reach a better cooling performance. The pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Compared with traditional linear solution fansink, the dissipation area increases 70% and the dissipation performance is 35% better. The WINDFORCE 3X 450 W cooling solution technology provides a more efficient air flow and better performance for the cooling system.
NVIDIA CUDA technology unlocks the power of the hundreds of cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications. The CUDA technology already adopted by thousands of programmers to speed up those performance hungry computing applications.
Gigabyte N670OC-4GD graphics card - GF GTX 670 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 670
4 GB GDDR5
Core Clock
980 MHz
Boost Clock
1058 MHz
Effective Memory Clock
6.008 GHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
4
DisplayPort , HDMI , DVI-I (dual link) , DVI-D (dual link)
API Supported
DirectX 11, OpenGL 4.2
6.2 cm x 29.5 cm x 12.9 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
980 MHz
Boost Clock
1058 MHz
Process Technology
28 nm
Max Resolution
2560 x 1600
4
API Supported
Ultra Durable VGA, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia 3D Vision Surround Ready, GIGABYTE WindForce 3x, Nvidia SLI ready, Triangle Cool Technology, Gold plated HDMI, TXAA, FXAA, NVIDIA Adaptive Vertical Sync, OC Guru II , HDCP
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
256-bit
Required Power Supply
550 W
Software Included
OC Guru ll
RoHS
6.2 cm
29.5 cm
12.9 cm
Scroll to top
