Click to visit BT.com
BT.com
Wishlist
Gigabyte GeForce GTX 660 Ti 2GB PCI-Express 3.0 HDMI OC Includes Borderlands 2
Quicklinx: 87WZWS00
Mfr#: GV-N66TOC-2GD-EU
Main Features
  • GPU:NVIDIA GeForce GTX 660 Ti - Faster, Smoother, Richer Gaming Experience
  • Features GPU Boost (Dynamic clocking)
  • Base OC to 1032 MHz (std: 915 MHz) ; Boost OC to 1111 MHz (std: 980 MHz)
  • Up to 4 Displays on a single GPU
  • GIGABYTE WINDFORCE™ 2X cooling design (with "Triangle Cool" technology)
  • 6.3% Performance better than GeForce GTX 660 Ti
  • 52% Performance better than GeForce GTX 570
  • 84.4% Performance better than GeForce GTX 560 Ti
  • 3.4% Performance better than Radeon HD 7970
  • 24.1% Performance better than Radeon HD 7950 (3DMark11 Extreme mode)
  • CUDA Core: 1344
  • TSMC 28nm Process GPU
  • Memory Amount: 2048MB
  • Microsoft DirectX 11 and OpenGL 4.2 support
  • NVIDIA® PhysX® technology / 3D Vision®-Ready
  • Features Dual-link DVI-I / DVI-D / DisplayPort / HDMI
  • 450 Watt or greater power supply recommended
Specification
  • GPU GeForce GTX 660 Ti
  • Core Base Clock 1032MHz (Std:915 MHz)
  • Core Boost Clock 1111 MHz (Std:980MHz)
  • Memory Clock 6008 MHz
  • Memory Size 2048MB GDDR5
  • Bus Type PCI Express 3.0
  • Memory Bus 192-bit
  • CUDA Cores 1344
  • Memory type 64Mx32
  • DirectX 11 Yes
  • DVI Port DVI-I /DVI-D
  • DisplayPort Yes
  • HDMI Yes
  • 3D'Vantage P: 30613 / X: 16070
  • 3D`11 P: 7580 / X: 2761
Gigabyte GV-N66TOC-2GD graphics card - GF GTX 660 Ti - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1032 MHz
Boost Clock
1111 MHz
CUDA Cores
1344
Effective Memory Clock
6.008 GHz
Memory Interface
192-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
4
DisplayPort , HDMI , DVI-I (dual link) , DVI-D (dual link)
API Supported
DirectX 11, OpenGL 4.2
4.2 cm x 26.6 cm x 13.7 cm
Europe
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1032 MHz
Boost Clock
1111 MHz
CUDA Cores
1344
Process Technology
28 nm
Max Resolution
2560 x 1600
4
API Supported
Ultra Durable VGA, Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, GIGABYTE WindForce 2x, Triangle Cool Technology, Gold plated HDMI, TXAA, GPU Boost technology, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA)
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
192-bit
Required Power Supply
450 W
Additional Requirements
Two 6-pin power connectors
Supported Windows 7 Features
Windows Media Center
RoHS
4.2 cm
26.6 cm
13.7 cm
Europe
