BT.com
Wishlist
Gigabyte GeForce GTX 1080 XTREME 8GB GDDR5X WindforceStack
Delivery
Standard Due date unavailable
GeForce GTX 1080 Xtreme Gaming Premium Pack
Powered by GeForce® GTX 1080
WINDFORCE Stack 3x 100mm fan cooling system
Xtreme VR Link provides the best VR experience
16.8M customizable color lighting
Xtreme SLI bridge with light effect
Stylish Metal Back Plate
Titan X-grade Chokes and Capacitors for Extreme Durability
Intuitive Xtreme Engine
Xtreme Care provides 4 years warranty (Online registration required)
Core
Boost: 1936 MHz / Base: 1784 MHz in OC mode
Boost: 1898 MHz / Base: 1759 MHz in Gaming mode
XTREME PERFORMANCE
GIGABYTE Xtreme Gaming Series graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary NVIDIA® Pascal™ GPU architecture, Xtreme gaming graphics card brings you incredible gaming experience.
  • Pascal-powered graphics card give you superior performance and power efficiency
  • Support up to 8K display @60Hz (requires 2*DP1.3 connectors)
  • Outstanding performance for Virtual Reality gaming
Gigabyte GeForce GTX 1080 Xtreme Gaming - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080
8 GB GDDR5X
Core Clock
1784 MHz
Boost Clock
1936 MHz
Effective Memory Clock
10.4 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
5.6 cm x 28.9 cm x 13.8 cm
4 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1784 MHz
Boost Clock
1936 MHz
Process Technology
16 nm
Max Resolution
7680 x 4320 at 60 Hz
4
API Supported
Ultra Durable VGA, LED indicator, GIGABYTE WindForce 3x, Dual ball Bearing Fan, NVIDIA G-Sync ready, NVIDIA GameWorks, 12+2 Phase Power Design, Nvidia GeForce GTX VR Ready
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10.4 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
2 x 8 pin PCI Express power connector
Backplate
Software Included
XTREME Engine Utility
5.6 cm
28.9 cm
13.8 cm
Limited warranty - 4 Years
Scroll to top
