BT.com
Wishlist
Gigabyte GeForce GTX 1080 XTREME 8GB GDDR5X Waterforce
Delivery
Standard Due date unavailable
GIGABYTE Xtreme Gaming Series graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary NVIDIA® Pascal™ GPU architecture, Xtreme gaming graphics card brings you incredible gaming experience.
  • Pascal-powered graphics card give you superior performance and power efficiency
  • Support up to 8K display @60Hz (requires 2*DP1.3 connectors)
  • Outstanding performance for Virtual Reality gaming
Gigabyte GeForce GTX 1080 Xtreme Gaming Water cooling - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080
8 GB GDDR5X
Core Clock
1784 MHz
Boost Clock
1936 MHz
Effective Memory Clock
10.416 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4.1 cm x 26.4 cm x 12.4 cm
4 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1784 MHz
Boost Clock
1936 MHz
Process Technology
16 nm
Max Resolution
7680 x 4320
4
API Supported
LED indicator, Triangle Cool Technology, NVIDIA G-Sync ready, NVIDIA GameWorks, WATERFORCE: All In One Water Cooling System, Nvidia GeForce GTX VR Ready
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10.416 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
4.1 cm
26.4 cm
12.4 cm
Limited warranty - 4 Years
Scroll to top
