BT.com
Wishlist
Gigabyte GeForce GTX 1080 Windforce OC 8GB GDDR5X PCIe Graphics
Delivery
Standard Due date unavailable
The WINDFORCE 3X cooling system features 3 pure copper composite heat-pipes, special fin architecture, unique blade fan design, together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming.
Gigabyte GeForce GTX 1080 WINDFORCE OC 8G - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080
8 GB GDDR5X
Core Clock
1657 MHz
Boost Clock
1797 MHz
Effective Memory Clock
10.01 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported
4
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4.1 cm x 28 cm x 11.4 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1657 MHz
Boost Clock
1797 MHz
Process Technology
16 nm
Max Resolution
4
API Supported
Ultra Durable VGA, LED indicator, MSI Solid Capacitor, GIGABYTE WindForce 3x, Three Fans Cooler, NVIDIA G-Sync ready, NVIDIA GameWorks, Heat Pipe Direct Touch technology, 8+2 Phase PWM Design, Nvidia GeForce GTX VR Ready
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10.01 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
Backplate
Software Included
XTREME Engine Utility
4.1 cm
28 cm
11.4 cm
Scroll to top
