BT.com
Wishlist
Gigabyte GeForce GTX 1070 mini-ITX OC 8GB GDDR5 PCIe Graphics Card
Delivery
Standard Due date unavailable
The GIGABYTE custom-designed cooling system features a 90mm fan, 3 pure copper composite heat-pipes, unique blade fan design, heat pipes direct touch technology together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle.
The composite heat-pipes combines both thermal conductivity and phase transition for efficiently managing the transfer of heat between two solid interfaces which increases 29% of cooling capacity.
Gigabyte GeForce GTX 1070 Mini ITX OC - graphics card - GF GTX 1070 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1070
8 GB GDDR5
Core Clock
1556 MHz
Boost Clock
1746 MHz
Effective Memory Clock
8.008 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
2 x DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.7 cm x 16.9 cm x 13.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1556 MHz
Boost Clock
1746 MHz
Process Technology
16 nm
Max Resolution
7680 x 4320
4
API Supported
NVIDIA G-Sync ready, NVIDIA GameWorks, GIGABYTE custom-designed 90 mm cooler, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
Software Included
XTREME Engine Utility
3.7 cm
16.9 cm
13.1 cm
Scroll to top
