BT.com
Wishlist
Gigabyte GeForce GTX 1060 XTREME GAMING 6GB GDDR5 PCIe Graphics Card
Delivery
Standard Due date unavailable
Crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Base on the revolutionary NVIDIA Pascal GPU architecture and cleverly designed for VR. It boasts high-specs and a variety of technologies to push your gaming limits to the max. There are various aspects to the cooling system embedded into the 1060 Xtreme Gaming GPU, that come together to create an impressive and effective heat dissipation system. This 1060 cooling features GIGABYTE patent-pending 3x 100mm stacked fans, unique blade fan design, double ball bearing structure, angular fin design and 6 composite heat-pipes with direct touch on the GPU. Experience higher performance at lower temperatures with the XTREME GTX 1060.
Clever layering of this 1060's fans has allowed for larger fans (100mm) to be installed, providing a larger and more smooth airflow. Compared to the standard 3x 80mm fans , the WINDFORCE stack fans create 10% enhanced cooling performance.
What's in the box
  • Gigabyte GeForce GTX 1060 Xtreme Gaming 6G
  • XTREME Engine Utility
  • Backplate
Gigabyte GeForce GTX 1060 Xtreme Gaming 6G - OC Edition - graphics card - GF GTX 1060 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
6 GB GDDR5
Core Clock
1645 MHz
Boost Clock
1873 MHz
Effective Memory Clock
8.316 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
5.7 cm x 28 cm x 13.2 cm
4 years warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1645 MHz
Boost Clock
1873 MHz
Process Technology
16 nm
VR Ready
Max Resolution
7680 x 4320 at 60 Hz
4
API Supported
Ultra Durable VGA, LED indicator, heatpipe cooling, GIGABYTE WindForce 2x, 6+1 Phase Power System, NVIDIA G-Sync ready, NVIDIA GameWorks, Nvidia GeForce GTX VR Ready
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8.316 GHz
Bus Width
192-bit
Required Power Supply
400 W
Additional Requirements
8 pin PCI Express power connector
Backplate
Software Included
5.7 cm
28 cm
13.2 cm
Limited warranty - 4 Years
Scroll to top
