BT.com
Wishlist
Gigabyte GeForce GTX 1060 mini-ITX OC 6GB GDDR5 PCIe Graphics Card
Delivery
Standard Due date unavailable
Equipped with 2 pure copper heat pipes and unique-blade fan with 3D active functionality, and heat pipes direct touch technology, the cooler can dissipate heat effectively from the GPU while keeping the fan at lower speed and noise.
Gigabyte GeForce GTX 1060 Mini ITX OC 6G - OC Edition - graphics card - GF GTX 1060 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
6 GB GDDR5
Core Clock
1556 MHz
Boost Clock
1771 MHz
Effective Memory Clock
8.008 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
2 x DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.7 cm x 16.9 cm x 13.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1556 MHz
Boost Clock
1771 MHz
Process Technology
16 nm
Max Resolution
7680 x 4320
4
API Supported
Ultra Durable VGA, NVIDIA G-Sync ready, NVIDIA GameWorks, GIGABYTE custom-designed 90 mm cooler, Heat Pipe Direct Touch technology, Nvidia GeForce GTX VR Ready
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
192-bit
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
Software Included
XTREME Engine Utility
3.7 cm
16.9 cm
13.1 cm
Scroll to top
