BT.com
Wishlist
Gigabyte GA-Z270X-Gaming 8 LGA1151 Intel Z270 DDR4 ATX
Delivery
Standard Due date unavailable
Bitspower G-Chill Hybrid Water Block
AORUS and Bitspower have teamed up to create a superior performance hybrid water block featuring a high-flow pure copper water channel that’s placed directly over VRMs for superior cooling. G1/4" threaded fittings ensure compatibility with any setup you plan to create.
  • Composite Armor: A sleek polygonal heatsink armor designed to give your liquid cooled system the cutting edge look it needs.
  • Rubber Seals: Designed to withstand maximum pressure allowing users to obtain the most performance from their liquid cooled PC.
  • Copper Channel: With a high thermal conductivity nickel hexavalent chromium plate combined with a pure copper water channel funnelling directly from the integrated G1/4" Threaded Fittings. The G-Chill Hybrid Water Block was designed to be durable and superior at siphoning heat.
  • Thermal Padding: To ensure that all the critical points are covered thermal pads are used to help bridge the gap between VRMs and the liquid cooling block.
What's in the box
  • Gigabyte GA-Z270X-Gaming 8
  • 4 x Serial ATA cable
  • SLI bridge
  • Cable ties, I/O back plate, dust covers, 2 thermistor cables, G-Connector, 2 RGB (RGBW) LED strip extension cables
  • Software
Gigabyte GA-Z270X-Gaming 8 - 1.0 - motherboard - ATX - LGA1151 Socket - Z270
Motherboard - ATX
Chipset Type
Intel Z270 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA-600, 2 x SATA Express port, 2 x M.2, 2 x U.2 port
USB / FireWire Ports
USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 5 x USB 3.1 Gen 1 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Graphics
MegaChips MCDP2800
Audio
HD Audio (6-channel)
LAN
Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel Z270 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3800 MHz (O.C.), 3666 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.), 4133 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
Graphics Controller
MegaChips MCDP2800
Audio
Audio Codec
Creative Sound Core3D
High Definition Audio, EAX ADVANCED HD 5.0, VoiceFX
LAN
Network Controller
Killer Gaming E2500 / 1535
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (x8 mode if PCI Express 3.0 x8 slot is occupied)) , 1 x PCIe 3.0 x16 (x8 mode (x4 mode if PCI Express 3.0 x4 slot is occupied)) , 2 x PCIe 3.0 x16 (x4 mode) , 2 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin SATA, 2 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , SATA-600 / PCIe 3.0 -connectors: 2 x M.2 , PCIe 3.0 -connectors: 2 x U.2 - RAID 0
1 x DisplayPort , 1 x HDMI , 1 x Thunderbolt 3/USB-C Gen2 , 1 x USB 3.1 Gen 2 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 2 x LAN (Gigabit Ethernet) , 5 x USB 3.1 Gen 1 , 1 x TOSLINK , 1 x PS/2 keyboard / mouse
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x Thunderbolt - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
Diagnostic LEDs, Q-Flash, AutoGreen, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, 15µ Gold Contact, On/Off Charge, Ultra Durable, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, Onboard Button, Easy RAID Installer, 3TB+ Unlock, GIGABYTE AMP-UP Audio, 2x Copper PCB, Black Solid Capacitors, Clear CMOS Button, WIMA film capacitors, TI Burr Brown OPA2134 operational amplifier, ECO button, Q-Flash Plus, Killer DoubleShot Pro, Nichicon Fine Gold Series Audio Capacitors, Turbo B-Clock, Game Boost, Ultra Durable PCIe Metal Shielding, GIGABYTE Double Locking Bracket, Ultra Durable Memory Armor, Anti-Sulfur Design, Ambient Surround LED, GIGABYTE USB DAC-UP 2, Intel Optane Memory Ready, GIGABYTE Smart Fan 5, Intel Thunderbolt 3 Controller, JRC NJM2114 operational amplifiers, Bitspower G-Chill Hybrid Water Block, Triple upgradable OP-AMPs
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup, GIGABYTE HW OC APP, GIGABYTE Smart Fan 5, GIGABYTE 3D OSD
Plug and Play
30.5 cm
24.4 cm
Scroll to top
