BT.com
Wishlist
Gigabyte GA-H170-D3HP Intel H170 S1151 DDR4 M.2 USB3.1 ATX
Gigabyte GA-H170-D3HP Intel H170...
£103.39
£103.39
Add to wishlist
Delivery
Standard Due date unavailable
• Supports 6th Generation Intel® Core™ Processor
• Dual Channel DDR4, 4 DIMMs
• Intel® USB 3.1 with USB Type-C™ - The World's Next Universal Connector
• 2-Way Graphics with Premium PCIe Lane
• PCIe Gen3 x4 M.2 Connector with up to 32Gb/s Data Transfer (PCIe & SATA SSD support)
• 2 SATA Express Connectors for up to 16Gb/s Data Transfer
• 115dB SNR HD Audio with Built-in Rear Audio Amplifier
• High Quality Audio Capacitors and Audio Noise Guard with LED Trace Path Lighting
• Intel® GbE LAN with cFosSpeed Internet Accelerator Software
• APP Center Including EasyTune™ and Cloud Station™ Utilities
• GIGABYTE UEFI DualBIOS™ Technology
• Support Intel® Small Business Advantage
GIGABYTE Ultra Durable ™ Motherboards
GIGABYTE 100 series motherboards support the latest 6th Generation Intel® Core™ processors, a 14nm desktop CPU which features improved performance, power efficiency and support for DDR4 memory, bringing cutting edge features and ultimate performance to your next PC build.
Connecting the Future - USB Type-C™
The USB Type-C™ port with USB 3.1 support is a robust and slim connector for all of your devices with reversible plug orientation
Fast Onboard Storage with 32Gb/s M.2
GIGABYTE M.2 solution offers considerably faster storage performance and support for both PCIe and SATA interface for M.2 SSD devices.
Gigabyte GA-H170-D3HP - 1.0 - motherboard - ATX - LGA1151 Socket - H170
Motherboard - ATX
Chipset Type
Intel H170 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x SATA Express port, 1 x M.2
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 3 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel H170 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
512 MB
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 3 x PCI , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCIe 3.0 x1
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 2 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 1 x HDMI , 3 x USB 3.0 , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x USB 3.1 , 1 x PS/2 keyboard / mouse , 1 x USB-C , 1 x DVI-D
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
Q-Flash, AutoGreen, Ultra Durable, AMD CrossFireX technology support, Intel Small Business Advantage support, Easy RAID Installer, 4K Ultra HD ready, GIGABYTE AMP-UP Audio, Audio Noise Guard with Path Lighting, GIGABYTE Smart Switch, GIGABYTE Ambient LED, LED Trace Path
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup
Plug and Play, ACPI 5.0
30.5 cm
22.5 cm
Scroll to top
