BT.com
Wishlist
Gigabyte GA-990FXA-UD5 R5 AMD AM3+ DDR3 USB3.0 ATX Motherboard
Gigabyte GA-990FXA-UD5 R5 AMD AM3+...
£151.59
6 due in 1-2 days
£151.59
Add to wishlist
Delivery
Standard Due date unavailable
This motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the GIGABYTE unique technologies. Featuring the USB 3.0 controller, AMD 900 series motherboards allow users to take advantage of super-fast USB transfer rates, delivering 10x faster data transfer compared to USB 2.0. Utilizing the advanced Serial ATA revision 3.0 solution, GIGABYTE AMD 900 series motherboards offer native 6 ports of high-speed data storage devices support with high data transfer speeds. The AMD 900 series motherboards introduce a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery.
Gigabyte GA-990FXA-UD5 R5 - 1.0 - motherboard - ATX - Socket AM3+ - AMD 990FX
Motherboard - ATX
Chipset Type
AMD 990FX / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Athlon II, Phenom II, FX
Data Bus Transfer Rate
5.2 GT/s
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3
Storage Ports
8 x SATA-600 (RAID), 2 x eSATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 8 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
5.2 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2000 MHz (O.C.)
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC1150
High Definition Audio, Dolby Home Theater
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 (x8 mode) , 2 x PCIe 2.0 x16 (x4 mode) , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
AMD SB950: SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD , Marvell 88SE9172: SATA-600 -connectors: 2 x 7pin SATA, 2 x 7pin eSATA - 4 devices - RAID 0 / RAID 1
1 x PS/2 keyboard / mouse , 1 x TOSLINK , 8 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
1 x audio - header , 6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x SPDIF out - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
Hardware Features
Q-Flash, NVIDIA SLI Technology Support, NVIDIA 3-way SLI Technology Support, On/Off Charge, Ultra Durable, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, ESD Protection, Audio Noise Guard with Path Lighting, Clear CMOS Button, Dedicated Audio Hardware Zone, Anti-Surge IC
Software Included
Norton Internet Security, @BIOS, EasyTune, Xpress Install
Plug and Play
30.5 cm
24.4 cm
Gigabyte GA-990FXA-UD5 R5 AMD AM3+ DDR3 USB3.0 ATX...
£151.59
Save on this ideal PC Build kit!
Save £8.29
£170.76
Scroll to top
