BT.com
Wishlist
Gigabyte GA-6PXSVT 1.0 ATX LGA2011 DIMM C602
Gigabyte GA-6PXSVT 1.0 ATX LGA2011...
£358.17
£358.17
Add to wishlist
Delivery
Standard Due date unavailable
GA-6PXSVT is a versatile motherboard. It is an optimal choice for workstations handling vast amounts of data, from content-generating machines that need to communicate their output in real time over a network, to workstations that simply need to perform daily backups of several drives over the network. GA-6PXSVT has advanced memory frequency that benefits to high density and memory intensive applications, such as high frequency trading, telecommunication networks, mobile data transfers and so on. This motherboard can also receive several SATA devices to build large storage arrays.
Gigabyte GA-6PXSVT - 1.0 - motherboard - ATX - LGA2011 Socket - C602
Motherboard - ATX
Chipset Type
Intel C602
Processor Socket
1 x LGA2011 Socket
Compatible Processors
Xeon E5-1600 series, Xeon E5-2600 series, Xeon E5-2600 v2 series, Xeon E5-1600 v2 series
Max RAM Size
32 GB
RAM Supported
8 DIMM slots - DDR3, non-ECC, ECC, registered, unbuffered
Storage Ports
10 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 3 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Graphics
ASPEED AST2400
Dedicated Video Memory
128 MB
LAN
10 Gigabit Ethernet, 2 x Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel C602
Processor Socket
LGA2011 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Registered, unbuffered
Single rank, dual rank, quad channel memory architecture, quad rank
Details
8 GB - unbuffered , 32 GB - registered
Graphics
Graphics Controller
ASPEED AST2400
128 MB
LAN
Network Controller
Intel 82574L / 82599EN
Network Interfaces
Expansion Slots
8 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 1 x CPU
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9230: SATA-600 -connectors: 8 x 7pin Serial ATA - 8 devices - RAID 0 / RAID 1 / RAID 10 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
4 x USB 3.0 , 2 x USB 2.0 , 1 x VGA , 1 x PS/2 keyboard / mouse , 1 x LAN (10Gigabit Ethernet) , 2 x LAN (Gigabit Ethernet) , 1 x serial
Internal Interfaces
2 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x USB 2.0 - Type A
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
Hardware Features
Clear CMOS Button
I/O back plate
2 x Serial ATA cable
30.5 cm
24.4 cm
Scroll to top
