BT.com
Wishlist
Gigabyte Force M7 Thor Gaming Mouse
Gigabyte Force M7 Thor Gaming...
£26.10
£26.10
Add to wishlist
Delivery
Standard Due date unavailable
Pro-laser Gaming Mouse
Professional-grade laser sensor offers lightning fast 12,000 fps image processing capability for absolute control and precise mouse movement. Advanced laser engine offers optimum and reliable performance, the FORCE M7 THOR is truly worthy to be named after the son of Odin!
FORCE M7 THOR is capable of using exclusively intuitive software application to customize button settings, sensitivities, and also simulate keypress of keyboard based on gamer's needs. FORCE M7 THOR features a non-slick, anti-abrasion coating and rubberized grip that allows for exceptional grip and comfort during long period gameplay.
  • Powered by 6000dpi Advanced Gaming Laser Sensor
  • Tracking capability of image processing up to 12000fps
  • Mouse Tracking Speed up to 150ips
Professional-grade laser sensor offers lightning fast 12,000 FPS image processing capability for absolute control and precise mouse movement. Advanced laser engine offers optimum and reliable performance, the FORCE M7 THOR is truly worthy to be named after the son of Odin!
Ergonomic Grip with Ideal Shape for comfortable Gameplay
Supreme ergonomically designed grip using an efficient and ideal stylized shape for user comfort, maximum stability, and precision movement during frenzied use
3-Stage DPI Adjustment
800/1600/5600 3-Stage DPI adjustable switch with 3-Stage LED indicators for quick on-the-fly DPI adjustment
Ultra-durable USB Cable
Reinforced USB cable for maximum durability
Gold plated USB connector for optimum signal transfer
5 Programmable Buttons
Non-slick Coating
Gaming Grade Feet Pads
Large size of gaming grade feet pads provides maximum smooth glide. Glide your FORCE M7 THOR as fast as your desire.
Gigabyte FORCE M7 THOR - mouse - USB - black
Mouse
Wired - USB
7.8 cm x 13.7 cm x 4.1 cm
110 g
Movement Detection Technology
Laser
Buttons Qty
5
Movement Resolution
6000 dpi
Performance
30 G maximum acceleration, 12000 fps, 150 inches per second, realtime sensitivity switching 800/1600/5600 dpi
Golden USB plug, 3 stage DPI indicator, on-the-fly DPI switching, anti-slip
1 x USB cable - integrated - 1.8 m
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Mouse
7.8 cm
13.7 cm
4.1 cm
110 g
Input Device
Wired
USB
Laser
Buttons Qty
5
Movement Resolution
6000 dpi
Performance
1 x USB - 4 pin USB Type A
BSMI, FCC, KCC
Scroll to top
