BT.com
Wishlist
Gigabyte FORCE M7 Sapphire Blue Optical Gaming Mouse - 5 button - USB
Gigabyte FORCE M7 Sapphire Blue...
£14.59
£14.59
Add to wishlist
Delivery
Standard Due date unavailable
Powered by 3200dpi Blue Gaming Optical Sensor
Professional-grade sapphire blue optical sensor offers optimum tracking resolution for precise control and movement. Mouse Movement Boost with up to 30g of added Acceleration
Ergonomic Grip with Ideal Shape for comfortable Gameplay
Supreme ergonomically designed grip using an efficient and ideal stylized shape for user comfort, maximum stability, and precision movement during frenzied use.
3-Stage DPI Adjustment
800/1600/3200 3-Stage DPI adjustable switch with 3-Stage LED indicators for quick on-the-fly DPI adjustment
Ultra-durable USB Cable
Reinforced USB cable for maximum durability
Gold plated USB connector for optimum signal transfer
5 Programmable Buttons
FORCE M7 is capable of using exclusively intuitive software application to customize button settings, sensitivities, and also simulate keypress of keyboard based on gamer's needs.
Non-slick Coating
FORCE M7 features a non-slick, soft-touch coating that is hand-sweat resistant, which allows for exceptional grip and comfort during long period gameplay.
Gaming Grade Feet Pads
Large size of gaming grade feet pads provides maximum smooth glide. Glide your FORCE M7 as fast as your desire.
Powered by 3200dpi blue gaming optical sensor
Mouse movement boost with up to 30G of added acceleration
On-the-fly DPI switching
Gigabyte FORCE M7 - mouse - USB - dark blue
Mouse
Wired - USB
Dark blue
7.8 cm x 13.7 cm x 4.1 cm
115 g
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
3200 dpi
Performance
30 G maximum acceleration, up to 65 inches per second, realtime sensitivity switching 800/1600/3200 dpi, 3600 fps
Golden USB plug, 3 stage DPI indicator, on-the-fly DPI switching, anti-slip
1 x USB cable - integrated - 1.8 m
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Mouse
7.8 cm
13.7 cm
4.1 cm
115 g
Dark blue
Input Device
Wired
USB
Optical
Buttons Qty
5
Movement Resolution
3200 dpi
Performance
1 x USB - 4 pin USB Type A
BSMI, FCC, KCC
Scroll to top
