Click to visit BT.com
BT.com
Wishlist
Gigabyte Force K7 Stealth Gaming Keyboard
Switchable Backlight Options and WASD Anti-Ghosting!
Quicklinx: 914MWS00
Mfr#: FORCE K7
Recommended Use: Gaming
Type: Keyboard
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
Standard delivery Delivered within 3-5 working days
16 in stock
£29.19
Force K7 - Stealth Gaming Keyboard
  • Ultra short key travel
  • 3-color backlighting
  • Selective anti-ghosting around WASD cluster
  • Dynamic volume and backlit illumination control
Scissor-Key Structure
Built with slim scissor-key structure, FORCE K7 ensures extreme short actuation distance and stable key presses. Ultra-slim keycaps also minimize the typing effort in keyboarding.
Anti-ghosting Capability Around WASD Cluster
Anti-ghosting capability around the WASD cluster on FORCE K7 guarantees the general gaming combination keys are registered and executed without conflict. Never be hurt by the missing signal failure during you press multiple keys simultaneously for the gaming commands.
3-color Backlight Illumination
Lighting up in the darkness, FORCE K7 offers 3 switchable illumination color options -Blue/Green/Cyan. Plus, these colors allowing stepless-adjustment makes you find the optimum brightness level based on the background condition.
Dynamic Volume and Backlit Control
Intuitive wheel based volume and backlit illumination control for easy hassle-free adjustments during intense gaming sessions.
Windows Lock Functionality
The Win-lock key with independent indicator allows you to disable the Windows key and prevent accidental activation of the Windows Start function during gaming session, so you'll never be worried about throwing your game by hitting the wrong keys
Hot-link Function Keys
The convenient function keys (F1~F12) offer you a quick and easy access to the most common functions and social networking sites.
Extended Rest Area for Better Comfort
Extended rest area at an ergonomically optimized angle perfectly supports your hands while holding on W/ A/ S/ D or the 4-direction keys and ensures hours upon hours of comfortable gaming.
Adjustable Feet Stands
Non-slick rubber feet prevents slipping. Adjustable keyboard tilt by extending the feet stands allows you to find personal optimal wrist position.
Gigabyte Force K7 - keyboard
Keyboard
USB
Hot Keys Function
Volume, backlight control
Volume control wheel, Scissor Key Technology, anti-ghosting, Windows Lock key, swappable feet, 3 colours of illumination
48 cm x 19.5 cm x 2.65 cm
1.1 kg
Keyboard
USB
Input Device
Hot Keys Function
Keyboard Technology
Membrane
48 cm
19.5 cm
2.65 cm
1.1 kg
1 x USB cable - 1.8 m
BSMI, FCC, KCC
Microsoft Windows Vista / XP / 7 / 8
Gigabyte Force K7 Stealth Gaming Keyboard Bundle deal on Gigabyte Force K7 Stealth Gaming Keyboard
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£39.18
Type: Keyboard
Colour: Black
Compatibility: PC
Cherry MX Switch Colour: [N/A]
Brand: Gigabyte
Price Range Inc VAT: 0 - 50
