Click to visit BT.com
BT.com
Wishlist
Gigabyte F2A85X-UP4 AMD FM2 A85X DDR3 ATX
Quicklinx: 8B92WS00
Mfr#: GA-F2A85X-UP4
Essential accessories
GIGABYTE FM2 motherboards are the latest range of next-generation desktop motherboards based on the AMD A85X chipset, supporting a new generation socket FM2 of 32nm AMD A-series APUs with DirectX11 graphics integrated. Not only delivering AMD's industry-leading performance and advanced graphics capabilities, GIGABYTE motherboards are equipped with a comprehensive range of unique features that offer mainstream PC users the most compelling platform on the market today.
AMD Eyefinity Technology
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
AMD Dual Graphics: Unrivalled Upgradability
The AMD A85X/A75/A55 series platform showcases AMD Dual Graphics technology, allowing users to further boost 3D graphics performance by adding an additional discrete AMD Radeon™ HD 6000 series graphics card* to the system. This unique Dual Graphics technology means users can enjoy higher frame rates on the latest gaming titles, utilizing the processing power of both discrete and integrated graphics processors.
Multi-display support with AMD CrossFire
Flexible graphics capabilities - Up to 3 VGA cards are supported for 3 way AMD CrossFireX™ (running at x8, x8, x4 bandwidth), delivering the ultimate in graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution.
GIGABYTE 333 Onboard Acceleration
GIGABYTE motherboards feature GIGABYTE 333 Onboard Acceleration , a range of the latest technologies that are designed help speed up data transfer, including SuperSpeed USB 3.0 technology, SATA Revision 3.0 (6Gbps) technology and an unprecedented 3x USB power boost on USB ports for more power hungry USB devices.
Triple-Monitor support
This motherboard provides Dual-link DVI, display port, HDMI and D-sub ports, allowing you to choose any three among four outputs to display at the same time!
GIGABYTE Ultra Durable™ 5: High Current, Low Heat CPU Power Zone Design Features IR Digital Power Controller and IR3550 PowIRstage® Ics
The GIGABYTE motherboard employ award winning GIGABYTE Ultra Durable™ 5 technology that includes high current capable components for the CPU power zone including IR3550 PowIRstage® ICs from International Rectifier, 2X Copper PCB and high current Ferrite Core Chokes rated up to 60A, which together are able to deliver cooler temperatures than traditional motherboards. Featured on a range of new motherboards based the AMD A85X Chipset, GIGABYTE Ultra Durable™ 5 technology is the next evolution in quality motherboard design.
GIGABYTE Digital Power Engine
GIGABYTE Ultra Durable 5 motherboards take advantage of an exclusive Digital PWM controller array, to deliver power to new generation of AMD FM2 A-series processor. Using digital controllers means that more precise power delivery to the motherboard's most power hungry and energy sensitive components is possible. These components include the CPU and processor graphics, without doubt the most important components on the motherboard. This Digital Power system, with Precise Auto Voltage Compensation to make real-time adjustments and deliver a steady flow of power to the system, no matter the loading. This all new, digital power system provides enthusiast users with exceptional control over the over -clocking potential of their GIGABYTE motherboard.
Gigabyte GA-F2A85X-UP4 - 1.0 - motherboard - ATX - Socket FM2 - AMD A85X
Motherboard - ATX
Chipset Type
AMD A85X
Processor Socket
1 x Socket FM2
Compatible Processors
Athlon II X4, A8 series, A6 series, A4 series, A10 series
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR3
Storage Ports
7 x SATA-600 (RAID), 1 x eSATA-600 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + ( 2 x USB 3.0 + 8 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
AMD A85X
Processor Socket
Socket FM2
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Dual channel memory architecture, AMD Memory Profile (AMP)
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 ( x8 mode ) , 1 x PCIe 2.0 x16 ( x4 mode ) , 3 x PCIe 2.0 x1 , 1 x PCI , 4 x DIMM 240-pin ( 1.5 V ) , 1 x CPU
Storage Interfaces
SATA-600 -connectors: 7 x 7pin SATA, 1 x 7pin eSATA - 7 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD
1 x PS/2 keyboard / mouse , 1 x VGA , 1 x DVI-D (dual link) , 1 x HDMI , 1 x DisplayPort , 4 x USB 3.0 , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x TOSLINK
Internal Interfaces
1 x SPDIF out - header , 1 x audio - header , 2 x USB 3.0 , 4 x USB 2.0 , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS, GIGABYTE 3D BIOS
Hardware Monitoring
CPU core temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, AutoGreen, On/Off Charge, AMD Radeon Dual Graphics, GIGABYTE 333 Onboard Acceleration, AMD CrossFireX technology support, Lucid Virtu MVP, Ultra Durable 5, MSI 3TB+ Infinity, AMD Eyefinity Technology
Software Included
Norton Internet Security, @BIOS, Q-Share, EasyTune, Xpress Install
Plug and Play, ACPI 2.0a, Energy-Related Products (ErP) Lot 6
30.5 cm
24.4 cm
