BT.com
Wishlist
Gigabyte F2A55M-HD2 AMD FM2 A55 DDR3 mATX
Delivery
Standard Due date unavailable
GIGABYTE FM2 motherboards are the latest range of next-generation desktop motherboards based on the AMD A55 chipset, supporting a new generation socket FM2 of 32nm AMD A-series APUs with DirectX11 graphics integrated. Not only delivering AMD's industry-leading performance and advanced graphics capabilities, GIGABYTE motherboards are equipped with a comprehensive range of unique features that offer mainstream PC users the most compelling platform on the market today.
  • GIGABYTE 3D BIOS technology with Dual UEFI BIOS design
  • GIGABYTE Ultra Durable™4 Classic technology
  • Supports socket FM2 AMD A-series/ Athlon-series processors
  • Enhanced AMD Radeon HD 7000-series graphics (DX11) integrated with the APU
  • 1 PCI-E 2.0 x16 interface with AMD Dual Graphics and Eyefinity support
  • Features HDMI/ Dual-link DVI/ D-sub ports for Triple-Monitor support
  • 8 USB2.0 and 4 SATA2 ports with RAID 0,1,10 support
  • GIGABYTE On/Off Charge technology
  • 3 Years Manufacturers Warranty
Specifcations
  • APU FM2 Socket: AMD A series processors, AMD Athlon™ series processors
  • Chipset: AMD A55
  • Memory: 2 x 1.5V DDR3 DIMM sockets supporting up to 64 GB of system memory, Dual channel memory architecture, Support for DDR3 1866/1600/1333/1066 MHz memory modules, Support for Extreme Memory Profile (XMP) memory modules
  • Onboard Graphics APU: 1 x D-Sub port, 1 x DVI-D port, supporting a maximum resolution of 2560x1600, 1 x HDMI port, supporting a maximum resolution of 1920x1200
  • Audio: Realtek ALC887 codec?, High Definition Audio?, 2/4/5.1/7.1-channel, Support for S/PDIF Out
  • LAN: Realtek GbE LAN chip (10/100/1000 Mbit)
  • Expansion Slots: 1 x PCI Express x16 slot, running at x16, 1 x PCI Express x1 slot, 1 x PCI slot
  • Multi-Graphics Technology: Support for AMD Dual Graphics technology
  • Storage Interface Chipset: 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices, Support for RAID 0, RAID 1, RAID 10, and JBOD
  • USB Chipset: Up to 8 USB 2.0/1.1 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
  • Internal I/O Connectors: 1 x 24-pin ATX main power connector, 1 x 8-pin ATX 12V power connector, 4 x SATA 3Gb/s connectors, 1 x APU fan header, 1 x system fan header, 1 x front panel header, 1 x front panel audio header, 1 x S/PDIF Out header, 2 x USB 2.0/1.1 headers, 1 x serial port header, 1 x Clear CMOS jumper
  • Back Panel Connectors: 1 x PS/2 keyboard/mouse port, 1 x D-Sub port, 1 x DVI-D port, 1 x HDMI port, 4 x USB 2.0/1.1 ports, 1 x RJ-45 port, 3 x audio jacks (Line In/Line Out/Microphone)
  • I/O Controller: iTE I/O Controller Chip
  • H/W Monitoring: System voltage detection, APU/System temperature detection, APU/System fan speed detection, APU overheating warning, APU/System fan fail warning, APU/System fan speed control
  • BIOS: 2 x 32 Mbit flash, Use of licensed AMI EFI BIOS, Support for DualBIOS™, PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
  • Warranty: 3 Years Manufacturers Warranty
Gigabyte GA-F2A55M-HD2 - 1.0 - motherboard - micro ATX - Socket FM2 - AMD A55
Motherboard - micro ATX
Chipset Type
AMD A55
Processor Socket
1 x Socket FM2
Compatible Processors
Athlon, A8 series, A6 series, A4 series, A10 series
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3
Storage Ports
4 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 2.0 + ( 4 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
AMD A55
Processor Socket
Socket FM2
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC887
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI , 1 x CPU , 2 x DIMM 240-pin ( 1.5 V )
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x PS/2 keyboard / mouse , 1 x VGA , 1 x DVI-D (dual link) , 1 x HDMI , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x audio - header , 1 x SPDIF out - header , 4 x USB 2.0 , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS, GIGABYTE 3D BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, AutoGreen, On/Off Charge, AMD Radeon Dual Graphics, Ultra Durable 4 Classic, AMD Eyefinity Technology
Software Included
Norton Internet Security, @BIOS, EasyTune 6, Q-Share, Xpress Install
Plug and Play, ACPI 2.0a, Energy-Related Products (ErP) Lot 6
22.5 cm
17.4 cm
Scroll to top
