BT.com
Wishlist
Gigabyte F2A55M-DS2 AMD FM2 A55 DDR3 mATX
Delivery
Standard 3-5 working days
GIGABYTE FM2 motherboards are the latest range of next-generation desktop motherboards based on the AMD A55 chipset, supporting a new generation socket FM2 of 32nm AMD A-series APUs with DirectX11 graphics integrated. Not only delivering AMD's industry-leading performance and advanced graphics capabilities, GIGABYTE motherboards are equipped with a comprehensive range of unique features that offer mainstream PC users the most compelling platform on the market today.
GIGABYTE 3D BIOS (patent pending)
The revolutionary GIGABYTE 3D BIOS application is based on GIGABYTE UEFI DualBIOS™ technology and is available to consumers in two exclusive modes of interaction, providing enthusiast and mainstream users with a choice of unique and powerful graphical interfaces.
UEFI DualBIOS™ Technology
At the heart of this exciting 3D BIOS technology is a pair of physical BIOS ROMs containing GIGABYTE's exclusive in-house designed UEFI BIOS technology. With a superior graphical interface capable of 32-bit color imaging and fluid user-friendly mouse navigation, UEFI DualBIOS™ makes BIOS configuration a new and exciting experience for novice and experienced users alike. UEFI BIOS also brings native support for large hard drives on 64-bit operating systems.
GIGABYTE Ultra Durable™ 4 Classic
  • Humidity Protection: Humidity can play havoc on a motherboard's circuitry.GIGABYTE's new Glass Fabric PCB design helps protect against electrical shorts due to humidity by reducing the gaps in spacing between PCB filaments.
  • Electrostatic Protection: GIGABYTE Ultra Durable 4 Classic motherboards feature High ESD Resistance ICs which help protect the motherboard against electrostatic discharge.
  • Power Failure Protection: Permanent damage from power surge or failure during BIOS update, can be avoided with GIGABYTE DaulBIOS, which automatically enables a secondary, back up BIOS.
  • High Temperature Protection: GIGABYTE uses Solid Caps (Capacitors) on CPU power zone and Low RDS(on) MOSFETs which are rated to work at higher temperatures.
AMD Eyefinity Technology
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
AMD Dual Graphics: Unrivalled Upgradability
The AMD A85X/A75/A55 series platform showcases AMD Dual Graphics technology, allowing users to further boost 3D graphics performance by adding an additional discrete AMD Radeon™ HD 6000 series graphics card* to the system. This unique Dual Graphics technology means users can enjoy higher frame rates on the latest gaming titles, utilizing the processing power of both discrete and integrated graphics processors.
Gigabyte GA-F2A55M-DS2 - 1.0 - motherboard - micro ATX - Socket FM2 - AMD A55
Motherboard - micro ATX
Chipset Type
AMD A55
Processor Socket
1 x Socket FM2
Compatible Processors
Athlon, A8 series, A6 series, A4 series, A10 series
Max RAM Size
64 GB
RAM Supported
2 DIMM slots - DDR3
Storage Ports
4 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 2.0 + (4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
AMD A55
Processor Socket
Socket FM2
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2400 MHz (O.C.)
Speed
PC3-12800, PC3-10600, PC3-8500, PC3-14900
Dual channel memory architecture, AMD Memory Profile (AMP)
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI , 1 x CPU , 2 x DIMM 240-pin (1.5 V)
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DVI-D (dual link) , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x audio - header , 1 x SPDIF out - header , 4 x USB 2.0 , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS, GIGABYTE 3D BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, AutoGreen, On/Off Charge, AMD Radeon Dual Graphics, Ultra Durable 4 Classic, AMD Eyefinity Technology
Software Included
Norton Internet Security, @BIOS, EasyTune 6, Q-Share, Xpress Install
Plug and Play, ACPI 2.0a, Energy-Related Products (ErP) Lot 6
22.5 cm
17.4 cm
Scroll to top
