BT.com
Wishlist
Gigabyte E-ATX SSI EEB DIMM Dual Gbe
Gigabyte E-ATX SSI EEB DIMM Dual...
£531.58
£531.58
Add to wishlist
Delivery
Standard Due date unavailable
The GA-7PESH3 gives you nothing less than the possibility to build a full-blown super workstation within a standard full tower desktop case. With up to 16 cores, 32 threads, 4 double slot GPU/co-processors, and connections for a storage array of up to 13 drives, your workflow can be accelerated with many teraflops of pure computing power.
Gigabyte GA-7PESH3 - 1.0 - motherboard - SSI EEB - LGA2011 Socket - C602
Motherboard - SSI EEB
Chipset Type
Intel C602
Processor Socket
2 x LGA2011 Socket
Compatible Processors
Xeon E5-2600 series
Max RAM Size
256 GB
RAM Supported
DDR3, ECC, registered, unbuffered
Storage Ports
8 x SAS (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
6 x USB 3.0 + 4 x USB 2.0 + (1 x USB 3.0 + 1 x USB 2.0 via headers)
Graphics
ASPEED AST2300
Audio
HD Audio (8-channel)
LAN
2 x Gigabit Ethernet
Chipset Type
Intel C602
Processor Socket
LGA2011 Socket
Max Processors Qty
2
Xeon E5-2600 series
Supported RAM
Max Size
256 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Registered, unbuffered
Quad channel memory architecture
Details
256 GB - registered - ECC , 64 GB - unbuffered - ECC
Graphics
Graphics Controller
ASPEED AST2300
Audio
High Definition Audio
LAN
Network Controller
Intel 82574L
Network Interfaces
Expansion Slots
2 x CPU , 8 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 3 x PCIe 3.0 x16 (x8 mode) , 3 x PCIe 3.0 x8
Storage Interfaces
LSI Logic LSISAS2008: SAS -connectors: 8 - 8 devices , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 1E / RAID 10 , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 1E / RAID 10
4 x USB 2.0 , 1 x serial , 1 x VGA , 4 x USB 3.0 , 2 x LAN (Gigabit Ethernet) , 1 x management , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
2 x USB 3.0 - Type A , 1 x USB 2.0 - header , 1 x audio - header , 1 x USB 3.0 - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
IPMI support, iKVM support
Hardware Features
NVIDIA 4-way SLI Technology Support, AMD CrossFireX technology support
33 cm
30.5 cm
Scroll to top
