BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Gigabyte Brix GB-BSi7H-6500 960GBSSD/4GB
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
  • Features Latest Intel® 6th generation Core Processors
  • Ultra compact PC design at only 0.6L
  • 120GB M.2 SSD
  • Optional 2.5" HDD/SSD support
  • 4GB DDR3L Memory (Upgradeable to 16GB)
  • Intel® Dual Band Wireless-AC 3165,IEEE 802.11a/b/g/n compatible
  • HDMI plus Mini DisplayPort Outputs (Supports dual displays)
  • Intel® HD Graphics 520
  • 4 x USB 3.0
  • Windows 10 Home (64-bit)
Challenging the essence of how we define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a brushed aluminum surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. With a broad choice of processors covering the entire performance spectrum, the BRIX sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit.
With the sixth-generation Intel Core processors, BRIX can outperform systems in both size and performance. Choices for system frequencies are 2.3 GHz for the Intel Core i3 and i5 or for those looking for something more powerful the Intel Core i7 at 2.5 GHz.
When processor-intensive applications are active, Turbo Boost 2.0 increases the clock speeds up to 2.8 GHz on the Core i5 and 3.1 GHz on the Core i7.
Keeping your files close at hand is even easier now with the BRIX. You never have to sacrifice between speed and storage space, with the BRIX you can choose to have both. By using next generation storage technologies, the BRIX is able to use PCIe-based flash storage allowing faster file transfers, shorter boot times, faster application launches, and quicker file access. Combined with support for a 2.5-inch drive you can now have the storage space you need and the speed you deserve.
With the ability to power two displays simultaneously the BRIX is a perfect choice as a high productivity PC in both the professional and home environments. Easily connect the BRIX to your UHD TV through Mini DisplayPort or HDMI for 4K playback and watch home videos or view your favorite pictures all in ultra-high definition.
Ready for whatever your world throws at it, the BRIX has multiple USB 3.0 ports for the many different peripherals you may have. With every BRIX, wireless technology is essential to the overall experience you have, 802.11ac wireless technology comes standard so you can easily connect to the internet at home. To make your life even more wire free, Bluetooth wireless technology is also built in so you can connect to your Bluetooth 4.2 capable phone, keyboard or mouse.
Windows 10 Home is the most innovative operating system yet from Microsoft®. It has dozens of new, exciting features to improve productivity and gaming, including full support for DirectX™ 12. Unlike its barebone counterpart, the BRIX Mini-PC System is preinstalled with Windows 10 Home for quick and easy setup.
Scroll to top
