BT.com
Wishlist
Gigabyte Brix GB-BSi5H-6200/480GBSSD/4GB
Gigabyte Brix...
£613.29
£613.29
Add to wishlist
Delivery
Standard Due date unavailable
  • Features Latest Intel® 6th generation Core Processors
  • Ultra compact PC design at only 0.6L (46.8 x 112.6 x 119.4mm)
  • Supports 2.5" HDD/SSD, 7.0/9.5 mm thick (1 x 6 Gbps SATA 3)
  • 1 x M.2 SSD (2280) slot
  • 2 x SO-DIMM DDR3L slot (1600MHz)
  • Intel® IEEE 802.11 ac ,Dual Band Wi-Fi & Bluetooth 4.2 NGFF M.2 card
  • HDMI plus Mini DisplayPort Outputs (Supports dual displays)
  • Intel® HD Graphics 520
  • 4 x USB 3.0
  • Intel Gigabit lan
  • Handset and Microphone jack
  • VESA mounting Bracket (75 x 75mm + 100 x 100mm)
Challenging the essence of how we define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a stylish glass surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. With a broad choice of processors covering the entire performance spectrum, the BRIX sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit.
With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect choice as a high productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
The BRIX is sold as a DIY PC kit, shipping with a NGFF M.2 Wi-Fi module pre-installed, plus a power adapter and cable conforming to local standards. Requiring only system memory and M.2 SSD, the BRIX gives users the flexibility to independently choose integrated storage and system memory size, without the trouble of sourcing components that are not widely available on the retail market.
Now there’s no waiting to resume activity on your PC. With Intel® Ready Mode Technology, your PC resumes to fully functional in an instant. It works by providing an alternative to traditional sleep-a quiet, low power state similar to the kind used by your cell phone and tablet...
With Intel® Ready Mode Technology You Can…
  • Get remote access to your PC through applications on your phone and tablet to download photos, video, large files and more, no matter where you are.
  • An always available PC complements Microsoft Windows® 10 enabled experiences Cortana. When you need Cortana, all you have to do is say "Hey Cortana," and your digital assistant is instantly at your service.
  • Set your Intel® Ready Mode Technology - equipped PC to sync and store photos and files across devices automatically when you arrive at home or the office. And application updates? They're automatic too, which means you'll always work with the latest versions of your favorite tools.
Bundled with a VESA bracket, the BRIX can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This makes it simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
Utilizing SATA III 6Gb/s high speed data transfer technology, the GIGABYTE BRIX s supports the installation of one 2.5" SATA hard drive and one M.2 SSD module. This allows for optimized storage configurations which combine fast SSD performance with larger capacity hard drives.
Other bundles
£613.29
Protect your Purchase!
Save £30.00
£623.28
£613.29
Keep your device tuned up!
£633.28
Scroll to top
