BT.com
Wishlist
Gigabyte Brix GB-BSi3H-6100/960GBSSD/4GB
Gigabyte Brix...
£621.15
£621.15
Add to wishlist
Delivery
Standard Due date unavailable
  • Features Latest Intel 6th generation Core Processors
  • Ultra compact PC design at only 0.6L (46.8 x 112.6 x 119.4mm)
  • Supports 2.5" HDD/SSD, 7.0/9.5 mm thick (1 x 6 Gbps SATA 3)
  • 1 x M.2 SSD (2280) slot
  • 2 x SO-DIMM DDR3L slot (1600 MHz)
  • Intel IEEE 802.11 ac ,Dual Band Wi-Fi & Bluetooth 4.2 NGFF M.2 card
  • HDMI plus Mini DisplayPort Outputs (Supports dual displays)
  • Intel HD Graphics 520
  • 4 x USB 3.0
  • Intel Gigabit lan
  • Handset and Microphone jack
  • VESA mounting Bracket (75 x 75mm + 100 x 100mm)
Challenging the essence of how we define a desktop PC, GIGABYTE engineers have developed an ultra compact PC with a stylish glass surface chassis design. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience. With a broad choice of processors covering the entire performance spectrum, the BRIX sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit.
With support for HDMI and DisplayPort, the BRIX can power two displays simultaneously, making a perfect choice as a high productivity PC in professional and home environments, or in any number of industrial and commercial multi-display applications.
The BRIX is sold as a DIY PC kit, shipping with a NGFF M.2 Wi-Fi module pre-installed, plus a power adapter and cable conforming to local standards. Requiring only system memory and M.2 SSD, the BRIX gives users the flexibility to independently choose integrated storage and system memory size, without the trouble of sourcing components that are not widely available on the retail market.
Bundled with a VESA bracket, the BRIX can easily be mounted behind a monitor or HDTV making it discreetly hidden from view. This makes it simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
Utilizing SATA III 6Gb/s high speed data transfer technology, the GIGABYTE BRIX s supports the installation of one 2.5" SATA hard drive and one M.2 SSD module. This allows for optimized storage configurations which combine fast SSD performance with larger capacity hard drives.
Scroll to top
