BT.com
Wishlist
Gigabyte B75M-D2V S1155 Intel B75 DDR3 mATX
Delivery
Standard 3-5 working days
Gigabyte B75 series motherboards possess a range of features that are designed to offer vastly improved and simplified control over unmanaged IT infrastructure, with specific focus on security, data backup and raising productivity levels overall.
Gigabyte GA-B75M-D2V - 1.0 - motherboard - micro ATX - LGA1155 Socket - B75
Motherboard - micro ATX
Chipset Type
Intel B75 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3 , non-ECC
Storage Ports
1 x SATA-600, 5 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 4 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel B75 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 1 x 7pin Serial ATA - 1 devices , SATA-300 -connectors: 5 x 7pin SATA - 5 devices
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DVI-D , 2 x USB 3.0 , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x audio - header , 2 x USB 3.0 , 4 x USB 2.0
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
Q-Flash, AutoGreen, All-Solid Capacitor motherboard Design, On/Off Charge, Ultra Durable 4 Classic, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel Small Business Advantage support, Intel Quick Sync Video 2.0
Software Included
Norton Internet Security, @BIOS, Q-Share, EasyTune, GIGABYTE EZ Setup, Xpress Install
Plug and Play, ACPI 2.0a, Energy-Related Products (ErP) Lot 6
22.6 cm
17.4 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Nice little board
Reviewed by Rich on 24/01/2014
Nice board for sandybridge or ivybridge. has one sata 3, usb3, pci3 express for latest graphics card and all for forty quid. top value with the spec, miles better than a H61 board.
Scroll to top
