BT.com
Wishlist
Gigabyte B75-D3V S1155 Intel B75 DDR3 ATX
Delivery
Standard Due date unavailable
Gigabyte 7 series motherboard takes advantage of the connectivity and expansion bus technologies on the Intel platform. The 3rd generation Intel Core processor platform debuts the PCI Express generation 3.0 expansion bus, allowing users to take advantage of the next generation, high-bandwidth discrete graphics card solutions.
Gigabyte 7 series motherboard features an onboard mSATA slot allowing users to easily take advantage of advanced SSD-based technologies like Intel Smart Response and Intel Rapid Start. Mounting an affordable, low capacity mSATA SSD directly onto your motherboard can enhance your PC's performance with better overall desktop responsiveness, faster boot times and faster system resume from 'suspend to disk' and 'standby' modes.
Gigabyte GA-B75-D3V - 1.0 - motherboard - ATX - LGA1155 Socket - B75
Motherboard - ATX
Chipset Type
Intel B75 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC
Storage Ports
1 x SATA-600, 5 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Intel B75 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Speed
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin (1.5 V) , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 3 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 1 x 7pin Serial ATA - 1 devices , SATA-300 -connectors: 4 x 7pin SATA, 1 x mSATA - 5 devices
1 x PS/2 keyboard / mouse , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x SPDIF out , 1 x audio , 4 x USB 2.0 , 2 x USB 3.0 , 1 x serial
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, AutoGreen, 3x USB Power Boost, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Ultra Durable 4 Classic, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, GIGABYTE LAN Optimizer
Software Included
@BIOS, Xpress Recovery 2, Q-Share
Plug and Play, ACPI 2.0a, Energy-Related Products (ErP) Lot 6
30.5 cm
21.5 cm
Scroll to top
