BT.com
Wishlist
Gigabyte ATX E5-1600 DIMM Dual Gbe
Delivery
Standard Due date unavailable
With two PCI-Express x16 Generation 3 slots supporting 2-way AMD CrossFireX and NVIDIA SLI modes, this motherboard can receive a duo of GPU working together to deliver ultra smooth utilization of CAD/CAE applications. With the GA-6PXSV3, you can build state of the art workstations that will dramatically speed-up your workflow.
The GA-6PXSV3 includes Gigabyte's digital PWM controllers, guaranteeing a dynamic power supply to the processor and memory with an ultra-fast response time. Built with advanced calibration tools, they allow getting the purest and most efficient electrical supply to date. When the CPU workload varies in function of the applications running, the Intel Turbo Boost Technology will do a dynamic overclock of the CPU cores. This is where the digital PWMs outshine the previous analog solutions. This way the CPU operations are much more stable, and the overall reliability of the system is greatly improved.
Gigabyte GA-6PXSV3 - 1.0 - motherboard - ATX - LGA2011 Socket - C604
Motherboard - ATX
Chipset Type
Intel C604
Processor Socket
1 x LGA2011 Socket
Compatible Processors
Core i7, Xeon E5-1600 series, Xeon E5-2600 series (Maximum TDP 150 Watt)
Max RAM Size
256 GB
RAM Supported
8 DIMM slots - DDR3, ECC, registered, unbuffered
Storage Ports
4 x SAS (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
6 x USB 2.0 + (4 x USB 3.0 via headers)
Graphics
ASPEED AST2300
Audio
HD Audio (8-channel)
LAN
2 x Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel C604
Processor Socket
LGA2011 Socket
Max Processors Qty
1
Supported RAM
Max Size
256 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Registered, unbuffered
Quad channel memory architecture
Details
256 GB - registered - ECC , 64 GB - unbuffered - ECC
Graphics
Graphics Controller
ASPEED AST2300
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Controller
Intel 82574L
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 2.0 x4 (x1 mode)
Storage Interfaces
SAS -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
4 x USB 3.0
BIOS Features
IPMI support, iKVM support
Hardware Features
NVIDIA SLI Technology Support, AMD CrossFireX technology support
30.5 cm
24.4 cm
Scroll to top
