BT.com
Wishlist
Gigabyte ATX E3-1200 INTEL 4xDIMM GBE
Gigabyte ATX E3-1200 INTEL 4xDIMM...
£289.09
£289.09
Add to wishlist
Delivery
Standard Due date unavailable
Still based on the 22 nm tri-gate lithography, this generation of Xeon processor is built on Intel's microarchitecture and brings up to 15% computing power improvements and increased L3 cache across the line. In addition, this generation will also bring to the Xeon E3 family the support of 1600 MHz ECC memory, Intel Trusted Execution and Virtualization technologies, as well as AVX 2.0 and TSX instructions. Last but not least, the Xeon E3-1200 V3 processor will include the latest Intel integrated graphics, which will bring the support of OGL3.2+, DirectX 11.1, and higher frequencies.
Gigabyte GA-6LXGL - 1.0 - motherboard - ATX - LGA1150 Socket - C224
Motherboard - ATX
Chipset Type
Intel C224
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Core i3, Xeon E3-1200 v3 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID), 2 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 3 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Graphics
ASPEED AST2400-VB
LAN
10 Gigabit Ethernet, 2 x Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel C224
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Unbuffered
Single rank, dual rank
Graphics
Graphics Controller
ASPEED AST2400-VB
LAN
Network Controller
Intel 82599 / I210
Network Interfaces
Expansion Slots
4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x1 , 3 x PCI , 1 x CPU
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
4 x USB 3.0 , 2 x USB 2.0 , 1 x VGA , 1 x PS/2 keyboard / mouse , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x LAN (10Gigabit Ethernet)
Internal Interfaces
2 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x USB 2.0 - Type A , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
30.5 cm
24.4 cm
Scroll to top
