BT.com
Wishlist
Gigabyte AMD Radeon R7 250 1100MHz 2GB PCI-E 3.0 HDMI OC
Delivery
Standard Due date unavailable
As opposed to the stereotype, Gigabyte is able to maximize fan size to 10 cm with the latest cooling design. With a 10 cm fan, the card is virtually silent that its noise level runs much lower.
  • Powered by AMD Radeon R7 250 GPU
  • Integrated with the first 2048MB DDR3 memory and 128-bit memory interface
  • OC Edition - Core Clock: 1100 MHz (Std 1050 MHz)
  • Features Single-Link DVI-D / HDMI / D-Sub
  • Support PCI Express 3.0 x8 bus interface
  • System power supply requirement: 400W
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK,FAN, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Gigabyte GV-R725OC-2GI (rev. 2.0) graphics card - Radeon R7 250 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x8
Graphics Engine
AMD Radeon R7 250
2 GB DDR3
Core Clock
1050 MHz
Boost Clock
1100 MHz
Effective Memory Clock
1.8 GHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Monitors Supported
2
DVI-D (Single-Link) , HDMI , VGA
API Supported
OpenGL 4.2, DirectX 11.1
3.5 cm x 19.5 cm x 13 cm
Graphics card
Bus Type
PCI Express 3.0 x8
Graphics Engine
AMD Radeon R7 250
Core Clock
1050 MHz
Boost Clock
1100 MHz
Process Technology
28 nm
Max Resolution
2560 x 1600
2
API Supported
Ultra Durable 2, AMD HD3D Technology, AMD App Acceleration, GIGABYTE custom-designed 100 mm cooler, Graphics Core Next (GCN), Gold plated HDMI, OC Guru II
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
128-bit
Required Power Supply
400 W
Software Included
AMD Catalyst Control Center, OC Guru ll
3.5 cm
19.5 cm
13 cm
Scroll to top
