BT.com
Wishlist
Gigabyte AMD Radeon R7 240 900MHz 2GB PCI-E 3.0 HDMI OC
Delivery
Standard Due date unavailable
As opposed to the stereotype, Gigabyte is able to maximize fan size to 10 cm with the cooling design. With a 10 cm fan, the card is virtually silent that its noise level runs much lower.
  • Powered by AMD Radeon R7 240 GPU
  • Integrated with the first 2048MB DDR3 memory and 128-bit memory interface
  • OC Edition - Core Clock: 900 MHz(Std 780 MHz)
  • Features Single-Link DVI-D / HDMI / D-Sub
  • Support PCI Express 3.0 x8 bus interface
  • System power supply requirement: 400W
Gigabyte GV-R724OC-2GI - graphics card - Radeon R7 240 - 2 GB
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R7 240
2 GB DDR3
Core Clock
780 MHz
Boost Clock
900 MHz
Effective Memory Clock
1.8 GHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Monitors Supported
2
DVI-D (Single-Link) , HDMI , VGA
API Supported
OpenGL 4.2, DirectX 11.2
3.5 cm x 19.5 cm x 13 cm
Graphics card
Bus Type
PCI Express 3.0
Graphics Engine
AMD Radeon R7 240
Core Clock
780 MHz
Boost Clock
900 MHz
Process Technology
28 nm
Max Resolution
2560 x 1600
2
API Supported
Ultra Durable 2, AMD HD3D Technology, AMD App Acceleration, GIGABYTE custom-designed 100 mm cooler, Graphics Core Next (GCN), Gold plated HDMI, OC Guru II
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
128-bit
400 Watt
Software Included
AMD Catalyst Control Center, OC Guru ll
3.5 cm
19.5 cm
13 cm
Scroll to top
