Click to visit BT.com
BT.com
Wishlist
Gigabyte AMD Radeon 6570 HD 670MHz 1GB PCI-Express 2.0 HDMI OC
Quicklinx: 8L6PWS00
Mfr#: GV-R657OC-1GI
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. Gigabyte is again setting a new standard, providing the stability and reliability from their high-end graphics solution. In addition, Gigabyte Ultra Durable 2 edition graphics cards feature a sophisticated layout topology. This state-of-the-art power design from Gigabyte delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
GIGABYTE HD Experience Series
  • Powered by AMD Radeon HD 6570 GPU
  • Integrated with the first 1GB DDR3 memory and 128-bit memory interface
  • Features Dual-link DVI-D / D-sub / HDMI
  • Overclock to 670 MHz
  • Support CrossFireX™ and Avivo™HD
  • System power supply requirement: 400W
Ultra Durable 2
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. GIGABYTE is again setting a new standard by using Ferrite Core Chokes, Low RDS (on) MOSFET and Lower ESR Solid Capacitors, providing the stability and reliability from their high-end graphics solution. In addition, GIGABYTE Ultra Durable 2 Edition graphics cards now feature a sophisticated layout topology. This state-of-the-art power design from GIGABYTE delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
  • Ultra Cooling - Low RDS(on) MOSFET Design
  • Low Power Loss - Ferrite Core Choke Design
  • Longer Life - All-Solid Capacitor Design
Gold plated HDMI
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections
GIGABYTE custom-designed 80 mm cooler
GIGABYTE custom-designed 80 mm cooler, with air flow optimized cover and aluminum base. The cooler can dissipate heat effectively from the GPU while keeping the fan at lower speed and noise.
AMD EyeSpeed: AMD EyeSpeed technology helps you
  • Enjoy beautifully rich and clear video playback when streaming from the web
  • Take in your favorite movies in stunning, stutter-free HD quality
  • Run multiple applications smoothly at maximum speed
  • Enjoy lightning fast game play and realistic physics effects
Cross Fire™
Multiply and Conquer with Multi-GPU Performance:CrossFire's "supertiling" GPU sharing speeds rendering by evenly dividing the graphics processing, intelligently alternating the rendering workload to each Radeon GPU for efficient load balancing, and optimized performance.CrossFire boosts image quality along with rendering speed, eliminating the need to crank down screen resolutions to get the high image quality you want.CrossFire supports a wide range of ATI-based graphics cards and motherboards, and offers compatibility with a broad array of third party components for a flexible and robust solution.
Avivo™ HD
Avivo™could provide vibrant high fidelity, flawlessly smooth next-generation video playback. Avivo™ technology easily allows your PCs to become digital home media center by its compelling video pipeline design that comprises the latest high definition video hardware acceleration, including H.264 and WMV9.
Microsoft Windows 7
Microsoft Windows 7 is the next generation operating system that will mark a dramatic improvement in the way the OS takes advantage of the graphics processing unit (GPU) to provide a more compelling user experience. By taking advangate of the GPU for both graphics and computing, Windows 7 will not only make todays's PCs more visual and more interactive but also ensure that they have the speed and responsiveness customers want
RoHS Compliant
As a citizen of the global village, GIGABYTE exert ourselves to be a pioneer in environment care. Give the whole of Earth a promise that our products do not contain any of the restricted substances in concentrations and applications banned by the RoHS Directive, and are capable of being worked on at the higher temperatures required for lead free solder. One Earth and GIGABYTE Cares!
  • Chipset Radeon HD 6570
  • PCB Form ATX
  • Core Clock 670 MHz
  • Shader Clock N/A
  • Memory Clock 1600 MHz
  • Process Technology 40 nm
  • Memory Size 1 GB
  • Memory Bus 128 bit
  • Card Bus PCI-E 2.1
  • Memory Type DDR3
  • DirectX 11
  • OpenGL 4.1
  • I/O HDMI * 1
  • DVI-D * 1
  • D-sub * 1
  • Digital max resolution 2560 x 1600
  • Analog max resolution 2048 x 1536
  • Multi-view 2
  • Card size H=32.5 mm, L=211.8 mm, W=129.9 mm
  • Power requirement 400 W
Gigabyte GV-R657OC-1GI graphics card - Radeon HD 6570 - 1 GB
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6570
1 GB - DDR3
Core Clock
670 MHz
Effective Memory Clock
1.6 GHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
2
DVI-D (dual link) , HDMI , VGA
API Supported
DirectX 11, OpenGL 4.1
3.3 cm x 21.2 cm x 13 cm
Graphics card
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon HD 6570
Core Clock
670 MHz
Max Resolution
2560 x 1600
2
API Supported
Avivo HD Technology, Ultra Durable 2, AMD Eyespeed, AMD CrossFireX Technology, GIGABYTE custom-designed 80 mm cooler
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
1.6 GHz
Bus Width
128-bit
Required Power Supply
400 W
RoHS
3.3 cm
21.2 cm
13 cm
