Click to visit BT.com
BT.com
Wishlist
Gigabyte Aivia Osmium Mechanical Gaming Keyboard - MX Red Switches
5.0*
Quicklinx: 87D9WS00
Mfr#: GKOSMIUM-RED-UK
Utilizing the revolutionary Anti-Ghosting Matrix key-switch design, Aivia Osmium provides Anti-Ghosting across all zones of the keyboard. Dominate the competition with the amazing advantage and versatility of being able to input multiple keystrokes at once. Never be hindered again on the battlefield as you twist, weave, and decimate your enemies through the unparalleled freedom of Absolute Anti-Ghost technology.
Optimized 45g actuation force
The Aivia Osmium gaming keyboard utilizes Cherry™ RED mechanical key-switches that provides superior tactile feedback and an optimized actuation force of 45g. Reduced key actuation distance of 2mm improves keyboard response time while remaining whisper silent during operation.
Ultra durability offering 50million key press lifespan
Superior materials and design improves key durability offering a staggering 50 million key press lifespan which is more than 10 times the amount of conventional keyboards
Equipped with USB 3.0 extension port
A built-in USB 3.0 output which enables the ability to extend USB 3.0 Superspeed support from the motherboard. Connect your USB3.0 device simply through the keyboard.
Enjoy USB3.0 Superspeed fast transmission
Independent USB3.0 signal transferring through motherboard ensures the full data transmission without any lose. 10X data transfer speed boost over USB 2.0
1.8X power supply compare to USB2.0
Absolute Anti-Ghosting Multi-Key Press Capability
Intuitive GHOSTTM Macro Engine
GHOST macro engine which features intuitive interface allows you to pre-define and switch between macro keys easily for latest PC gaming titles.
5 gaming profiles on the go
Profile switch at your fingertips enables you to switch between 5 different gaming profiles. Up to 70 macros memorization for the gamer on the go.
Other Features
Dynamic Volume & Backlit Illumination Control
Mechanical Macro Hotkey
Macro Profile Switch
Additional Feet Stands for the wrist rest
Full-sized Wrist Rest
18K Gold-plated Connector for Low Latency
Gigabyte Aivia Osmium Mechanical Gaming - keyboard
Keyboard
USB
Backlit, 2-port USB hub, Cherry MX Red technology
45.4 cm x 25.7 cm x 4.5 cm
1.5 kg
Keyboard
USB
Input Device
45.4 cm
25.7 cm
4.5 cm
1.5 kg
2 x USB , Headphone output , Microphone input
1 x USB cable - 2 m
BSMI, FCC
Microsoft Windows Vista / XP / 7
Customer reviews
Write a review for the Gigabyte Aivia Osmium Mechanical Gaming Keyboard - MX Red Switches here!
Premium Mechanical Keyboard, for a premium price
Reviewed by Dave. Review Posted 20/01/2013
Excellent cherry red mechanical keyboard with excellent features. It has USB3.0 extension port, microphone & headphone sockets, on a quality 18K Gold-plated connector braided cable. Rock solid construction, with adjustable blue back lighting & volume controls. Five profiles and five G keys for up to 70 macros Full anti ghosting across the whole keyboard, you don't normally see this on USB keyboards. Been using mine for a few months now, excellent for typing on & gaming. Robust keyboard, fast actuation switch's. It came in the delivery box protected with a dense type memory foam, Gigabyte really went to town on the packaging. If your looking at getting a keyboard like this you should already have some idea of what your looking for. Try out the different switch types to find what suits you best. The Gigabyte Aivia Osmium is a fine choice with excellent features not seem on some other mechanical keyboards & once you've used a mechanical keyboard you won't want to go back budget one
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
