BT.com
Wishlist
Gigabyte Aire M73 Eco-Friendly Wireless Mouse
Delivery
Standard Due date unavailable
Save your power anytime! The thoughtful design of on-the-top power key makes it more intuitive to power your mouse.
Curves and coating of AIRE M73 is just attractive that you'll find it hard to refuse. Ergonomic design is ideal for right-handed users, while the non-slip, plastic panels on the side provide comfort and extraordinary hand-feeling that is already more than satisfying to users.
Plug-and-Play technology makes it effortless to use the mouse on different devices. Tiny nano receiver ensures great experience of traveling with your notebook all the time!
Gigabyte AIRE M73 - mouse - 2.4 GHz - elegant matte black
Mouse
Wireless - 2.4 GHz
Elegant matte black
Orientation
Right-handed
7.6 cm x 12.3 cm x 4.3 cm
91 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
1000 dpi
Programmable buttons, scrolling wheel, battery indicator, on/off power switch, anti-slip side panels
AAA type
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Microsoft Windows XP 32-bit
2 years warranty
Mouse
Wireless Receiver
Orientation
Right-handed
7.6 cm
12.3 cm
4.3 cm
91 g
Elegant matte black
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 8 m
Optical
Buttons Qty
5
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
Plug and Play, BSMI, FCC, NCC
AAA type
Run Time (Up To)
7 months
Scroll to top
