BT.com
Wishlist
Gigabyte Aire M58 Compact Wireless Optical Mouse
Perfect For Using With Your Laptop!
Delivery
Standard Due date unavailable
Overview
  • GIGABYTE precise optical tracking system
  • 9-Month battery life
  • Enlarged scroll wheel and mouse feet
  • Comfortable grip for both hands
  • Stylish glossy coating
GIGABYTE Precise Optical Tracking System
Equipped with GIGABYTE' precise optical tracking system and reliable 2.4GHz wireless transmission technology, the mouse is so responsive and easy to control.
9-Month Battery Life
2 AAA batteries powers this mouse up to 9 months* so you don't have to worry about changing batteries.
* Battery performance is based on maximum theoretical interface values from respective Chipset vendors or organization who defined the interface specification. Actual performance may vary by user habit and system configuration.
Portable Nano Receiver
Plug-and-play technology makes it effortless to use the mouse on different devices. The tiny nano receiver ensures great experience of traveling with your notebook all the time!
Enlarged Scroll Wheel and Mouse Feet
Enlarged scroll wheel makes it even more comfortable when you surf the internet, and the big mouse feet ensures extra smoothness when you use the mouse.
Comfortable Grip for Both Hands
The useful grip design on the side gives ensures a pleasurable user experience, which is more comfortable for those who have sweaty palms. No more worrying about rubber-peeling or sticky rubber anymore!
Low-Power Indicator & Stylish Glossy Coating
When the battery is low, the low-power indicator will blink for 5 seconds, and then turn off. Simple and stylish glossy coating on the top shows your extraordinary taste.
Gigabyte AIRE M58 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
5.9 cm x 9.9 cm x 3.5 cm
60 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
Scrolling wheel
AAA type
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP 32-bit
2 years warranty
Mouse
Wireless Receiver
Orientation
5.9 cm
9.9 cm
3.5 cm
60 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 8 m
Optical
Movement Resolution
1000 dpi
Scrolling wheel
1 x USB 2.0 - 4 pin USB Type A
2 AAA batteries
BSMI, FCC
AAA type
Scroll to top
