BT.com
Wishlist
Gigabyte A75-D3H AMD FM1 Hudson D3 DDR3 ATX
Delivery
Standard Due date unavailable
GIGABYTE Super4™ motherboards are the latest range of next-generation desktop motherboards based on the AMD A75 chipset, supporting a new generation socket FM1 of 32nm AMD A-series/E-series APUs with DirectX11 graphics integrated. Not only delivering AMD's industry-leading performance and advanced graphics capabilities, GIGABYTE Super4™ motherboards are equipped with a comprehensive range of unique features that offer mainstream PC users the most compelling platform on the market today.
AMD Dual Graphics: Unrivalled Upgradability
The AMD A75 series platform showcases AMD Dual Graphics technology, allowing users to further boost 3D graphics performance by adding an additional discrete AMD Radeon™ HD 6000 series graphics card to the system. This unique Dual Graphics technology means users can enjoy higher frame rates on the latest gaming titles, utilizing the processing power of both discrete and integrated graphics processors.
AMD Fusion Graphics: Most Powerful Integrated Graphics Ever
Supporting Microsoft® DirectX® 11, OpenGL 4.1 and OpenCL 1.1 standards, AMD Fusion graphics deliver 3DMark Vantage (Performance setting) scores of over 6000 points, and a 3D gaming experience similar to entry-level discrete graphics card solutions.
Multi-display support with AMD CrossFireX
Flexible graphics capabilities - Up to 2 VGA cards are supported for 2 way AMD CrossFireX™ (running at x16, x4 bandwidth), delivering the ultimate in graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution.
  • Supports Socket FM1 of 32nm AMD A-series/E2-series processors
  • Enhanced AMD Radeon HD 65xx/64xx/63xx graphics (DX11) integrated with the processor
  • 2 PCI-E 2.0 interfaces with AMD Dual Graphics and CrossFireX technology support
  • Ultra Durable 2 Classic Technology with 4+1 phase power VRM designed
  • Supports 6 USB 3.0 interfaces with superfast transfer rates of up to 5Gbps
  • Supports 6 SATA3 storage interfaces with superfast 6Gbps link speed and RAID 0,1,10
  • GIGABYTE 3x USB Power with On/Off Charge USB ports
  • Integrated HDMI/Dual-link DVI/D-sub outputs for high resolution up to 2560x1600 Full HD playback
  • Hi-def 108dB Signal-to-noise ratio Blu-ray DVD audio playback
  • Patented DualBIOS with Hybrid EFI technology for 3TB HDD support
  • Supports Dolby Home Theater audio
Gigabyte GA-A75-D3H - 1.0 - motherboard - ATX - Socket FM1 - AMD A75
Motherboard - ATX
Chipset Type
AMD A75 / ITE IT8720
Processor Socket
1 x Socket FM1
Compatible Processors
A series, E2 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3
Storage Ports
5 x SATA-600 (RAID), 1 x eSATA-600 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + ( 2 x USB 3.0 + 8 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Processor Socket
Socket FM1
Max Processors Qty
1
A series, E2 series
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Speed
PC3-12800, PC3-10600, PC3-8500, PC3-15000
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC889
High Definition Audio, Dolby Home Theater
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin ( 1.5 V ) , 2 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1 , 3 x PCI
Storage Interfaces
SATA-600 -connectors: 5 x 7pin SATA, 1 x 7pin eSATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x PS/2 keyboard / mouse , 1 x TOSLINK , 2 x USB 2.0 , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x VGA , 1 x DVI-D , 1 x HDMI
Internal Interfaces
1 x audio , 1 x SPDIF out , 4 x USB 2.0 , 1 x USB 3.0 , 1 x serial
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
Award
BIOS Features
DMI 2.0 support, ACPI 1.0b support, SMBIOS 2.4 support, Hybrid EFI Technology, Xpress BIOS Rescue
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, power supply fan tachometer
Hardware Features
DualBIOS, Q-Flash, 4+1 Phase Power Design, AutoGreen, 3x USB Power Boost, EasyTune6, On/Off Charge, Ultra Durable 2 Classic, GIGABYTE Super4, GIGABYTE Super Speed, One Port One Fuse, AMD Radeon Dual Graphics, AMD CrossFireX technology support
Software Included
Norton Internet Security, @BIOS, Xpress Recovery 2, EasyTune 6, Q-Share
Plug and Play, ACPI 1.0b, Energy-Related Products (ErP) Lot 6
30.5 cm
22.5 cm
Scroll to top
