Click to visit BT.com
BT.com
Wishlist
Gigabyte 990FXA-UD5 AM3+ AMD 990FX SB950 DDR3 ATX
5.0*
Quicklinx: 7JF8WS00
Mfr#: GA-990FXA-UD5
Processor Socket: Socket AM3+
Chipset: AMD 990FX
Graphics: None
Form Factor: ATX
Memory Support: DDR3 SDRAM
Hurry, only 1 left in stock!
£138.68
Essential accessories
The 990FXA-UD5 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the Gigabyte 333 onboard acceleration technologies. Featuring the USB 3.0 controller, AMD 900 series motherboards allow users to take advantage of super fast USB transfer rates of up to 5Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA Revision 3.0 solution, Gigabyte AMD 900 series motherboards offer native 6 ports of next generation high speed data storage devices support with data transfer speeds of up to 6 Gbps with RAID 0, 1, 5, 10. The AMD 900 series motherboards introduce a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
Gigabyte GA-990FXA-UD5 - 1.0 - motherboard - ATX - Socket AM3+ - AMD 990FX
Motherboard - ATX
Chipset Type
AMD 990FX / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Athlon II, Phenom II X4, Phenom II X6
Data Bus Transfer Rate
5.2 GT/s
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3
Storage Ports
8 x SATA-600 (RAID), 2 x eSATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 1 x FireWire + 8 x USB 2.0 + ( 2 x USB 3.0 + 1 x FireWire + 6 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Max Bus Speed
2600 MHz
5.2 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Speed
PC3-12800, PC3-10600, PC3-8500, PC3-15000
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC889
High Definition Audio, Dolby Home Theater
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin ( 1.5 V ) , 2 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 , 2 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
AMD SB950 : SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD , Marvell 88SE9172 : SATA-600 -connectors: 2 x 7pin SATA, 2 x 7pin eSATA - 4 devices - RAID 0 / RAID 1
1 x PS/2 keyboard / mouse , 1 x TOSLINK , 8 x USB 2.0 , 2 x USB 3.0 , 1 x FireWire , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
1 x audio , 1 x SPDIF out , 3 x USB 2.0 , 1 x USB 3.0 , 1 x FireWire , 1 x serial
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
Award
BIOS Features
DMI 2.0 support, ACPI 1.0b support, SMBIOS 2.4 support, Hybrid EFI Technology, Xpress BIOS Rescue
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, power supply fan tachometer
Hardware Features
DualBIOS, Q-Flash, 8+2 Phase Power Design, AutoGreen, 3x USB Power Boost, NVIDIA 3-way SLI Technology Support, EasyTune6, GIGABYTE Easy Energy Saver, Ultra Durable 3, NVIDIA 2-way SLI Technology Support, On/Off Charge, GIGABYTE Turbo XHD, AMD CrossFireX technology support
Software Included
Norton Internet Security, @BIOS, Xpress Recovery 2, AMD OverDrive, EasyTune 6, Q-Share, Cloud OC
Plug and Play, ACPI 1.0b, Energy-Related Products (ErP) Lot 6
30.5 cm
24.4 cm
Gigabyte 990FXA-UD5 AM3+ AMD 990FX SB950 DDR3 ATX Bundle deal on Gigabyte 990FXA-UD5 AM3+ AMD 990FX SB950 DDR3 ATX
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£158.21
saving £8.68
Including:
£140.48
saving £1.80
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£148.67
Customer reviews
Write a review for the Gigabyte 990FXA-UD5 AM3+ AMD 990FX SB950 DDR3 ATX here!
Gigabyte 990FXA-UD5
Reviewed by Anonymous Review Posted 07/07/2012
Bought this board as a direct replcaement for an older AM2+ Board. Very simple to set up and install. The Board dropped in fine and is running now as I type, Paired with a FX8120 Processor and it has made a huge difference.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Chipset: AMD 990FX
Graphics: None
Form Factor: ATX
Max Processors: 1
Brand: Gigabyte
Stock Status: Clearance
Price Range Inc VAT: 100 - 150
