Click to visit BT.com
BT.com
Wishlist
Gigabyte 970A-DS3 AM3+ AMD 970 DDR3 ATX
5.0*
Quicklinx: 8DLYWS00
Mfr#: GA-970A-DS3
Essential accessories
The 970A-DS3 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the Gigabyte 333 onboard acceleration technologies. Featuring the USB 3.0 controller, AMD 900 series motherboard allows users to take advantage of super fast USB transfer rates of up to 5 Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA revision 3.0 solution via AMD chipset, Gigabyte AMD 900 series motherboard offers native 6 ports of high speed data storage devices support with data transfer speeds of up to 6 Gbps with RAID 0, 1, 5, 10. The AMD 900 series motherboard introduces a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
Gigabyte GA-970A-DS3 - 1.0 - motherboard - ATX - Socket AM3+ - AMD 970
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Athlon II, Phenom II X4, Phenom II X6, FX
Data Bus Transfer Rate
4.8 GT/s
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 6 x USB 2.0 + ( 6 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
4.8 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Speed
PC3-12800, PC3-10600, PC3-8500, PC3-14900
Dual channel memory architecture
Audio
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 , 3 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
AMD SB950 : SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD
1 x PS/2 keyboard , 1 x PS/2 mouse , 6 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x audio , 1 x SPDIF out , 6 x USB 2.0
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
Award
BIOS Features
DMI 2.0 support, ACPI 1.0b support, SMBIOS 2.4 support, Hybrid EFI Technology, Touch BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, power supply fan tachometer
Hardware Features
DualBIOS, 4+1 Phase Power Design, AutoGreen, 3x USB Power Boost, EasyTune6, On/Off Charge, GIGABYTE Turbo XHD, Ultra Durable 4 Classic, AMD CrossFireX technology support
Software Included
Norton Internet Security, @BIOS, Xpress Recovery 2, AMD OverDrive, EasyTune 6, Q-Share, Cloud OC
Plug and Play, ACPI 1.0b, Energy-Related Products (ErP) Lot 6
30.5 cm
22.5 cm
Customer reviews
Write a review for the Gigabyte 970A-DS3 AM3+ AMD 970 DDR3 ATX here!
works great
Reviewed by adam. Review Posted 08/05/2013
the price is great and it works fine with my FX8850! had no problems during set up
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
