Click to visit BT.com
BT.com
Wishlist
Garmin eTrex 10 Bundle
Quicklinx: 8LBBWS00
Mfr#: 010-00970-05
The eTrex 10 retains the core functionality, rugged construction, affordability and long battery life that made eTrex the most dependable GPS device available. You'll recognize the name. You'll recognize the quality.
Garmin eTrex 10 - GPS navigator
GPS navigator
Display
2.2 in monochrome - 128 x 160
Recommended Use
Hiking
USB
Protection
Waterproof
5.4 cm x 3.3 cm x 10.3 cm
142 g
GPS navigator
Recommended Use
Hiking
USB
Aerial
Built-in
Custom POIs, downloadable POIs, preinstalled POIs, hunt/fish calendar, Geocaching, Garmin Connect compatible
Display
LCD - monochrome
Diagonal Size
2.2 in
3.6 cm
4.3 cm
Resolution
128 x 160
Display Illumination
Navigation
Waypoints
1000
Tracks
100
Tracklog Points
10000
Routes
50
USB
Protection
Waterproof
Waterproof Standard
IPX7
5.4 cm
3.3 cm
10.3 cm
142 g
