BT.com
Wishlist
Gainward GeForce GTX 660 Ti 2GB PCI-Express 3.0 HDMI Phantom
Delivery
Standard Due date unavailable
The GeForce GTX 660 Ti is built for fast and fluid 1080p gaming in the latest DirectX 11 and NVIDIA PhysX enabled games. Packed with the excellent features, GeForce GTX 660 Ti delivers the ideal fusion of power, performance, and affordability.
Gainward GeForce GTX 660 Ti Phantom graphics card - GF GTX 660 Ti - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 660 Ti
2 GB GDDR5
Core Clock
1006 MHz
Boost Clock
1084 MHz
CUDA Cores
1344
Memory Interface
192-bit
Max Monitors Supported
4
DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort
API Supported
DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.2
24.7 cm x 11.2 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1006 MHz
Boost Clock
1084 MHz
CUDA Cores
1344
Process Technology
28 nm
4
API Supported
Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia 3D Vision Surround Ready, TXAA, FXAA, Gainward "Phantom II" design, NVIDIA Adaptive Vertical Sync, Gainward DrMOS, NVIDIA GPU Boost, Kepler GPU Architecture
Size
2 GB
GDDR5 SDRAM
Bus Width
192-bit
Bandwidth
146.6 GBps
Microsoft Windows Vista / XP / 7
Required Power Supply
450 W
Additional Requirements
Two 6-pin power connectors
6 pin PCIe power cable
Software Included
Drivers & Utilities, Gainward Expertool II
24.7 cm
11.2 cm
Scroll to top
