BT.com
Wishlist
Fujitsu USB Display Adapter Plus
Delivery
Standard Due date unavailable
This USB Display Adapter enables you to connect one more monitor, LCD or projector to a computer with a USB 2.0 port. For desktop users adding an extra monitor via USB, connection is easier than ever. No more having to open the computer chassis to install an internal video card. Once the installation is complete, the USBattached monitor soon wakes up. No function key hassle to swap to a second monitor.
Fujitsu USB Display Adapter - external video adapter - black
External video adapter
Bus Type
USB 2.0
Max Resolution
1440 x 1050
DVI-I
5.4 cm x 1.8 cm x 8.4 cm
Enclosure Colour
CELSIUS Mobile H700, H710, H910, H970; ESPRIMO C910, D556, D757, D757/E94, D956, D957, D957/E94, E400, P556, P756, P756 E94, P956/E94, P957, Q520, Q956; LIFEBOOK E554, E751, E780, E781, LH531, P3110, P701, P770, P771, PH530, S710, S751, S760, S761, T580, T730, T731, T900, T901, TH700; Stylistic Q550
Bus Type
USB 2.0
Max Resolution
1440 x 1050 at 85 Hz
DVI-I
Video Output
Supported Display Graphics
VGA (640x480), XGA (1024x768), SVGA (800x600), SXGA (1280x1024), 1280x960, 1440x900, 1366x768, 1440x1050
Microsoft Windows XP, Microsoft Windows Vista
Additional Requirements
CD-ROM, USB port
System Requirements Details
1.2 GHz - RAM 256 MB - HDD 30 MB
1 x USB cable - 1 m
Software Included
Drivers & Utilities
Plug and Play
5.4 cm
1.8 cm
8.4 cm
Enclosure Colour
10 °C
35 °C
8 - 85% (non-condensing)
Fujitsu CELSIUS Mobile H265, H270, H700, H710, H910 Dual Core, H910 Quad Core, H970 , Fujitsu ESPRIMO C910-L, D556/2/E85+, D556/E85+, D556/E90+, D757/E85+, D757/E90+, D757/E94+, D956/M (International Energy Star Program), D957/E85+, D957/E90+, D957/E94+, E400 E85+, P556 E85+, P556 E90+, P556/2/E85+, P756 E85+, P756 E90+, P756 E94+, P956/E94+, P957/power, Q520/K, Q956/MRE , Fujitsu ESPRIMO Mobile D9510, M9410, M9415, U9210, U9215, V6505, V6535, V6545, X9510, X9515, X9525 , Fujitsu LIFEBOOK E554, E751, E780, E781, E8010, E8010 Mainstream, E8010 Supreme, E8310, E8420, LH531, P3110, P701, P770, P771, P8010, P8020, P8110, PH530, S6420, S710, S7220, S751, S760, S761, T1010, T5010, T580, T730, T731, T900, T901, TH700 , Fujitsu Stylistic Q550
Scroll to top
