BT.com
Wishlist
Fujitsu SnapScan iX100 Mobile Wireless Document Scanner
Fujitsu SnapScan iX100 Mobile...
£190.51
More than 50 in stock
£190.51
Add to wishlist
Delivery
Standard 1-3 working days
The cross platform compatible ScanSnap iX100 brings the power and intuitiveness of the ScanSnap range of models to a compact and totally wireless format. The light-weight ScanSnap iX100 comes with a USB rechargeable Lithium-ion battery that is capable of up to 260 A4 scans on a full charge. Combined with an ability to scan either via a wireless network to PC workstations or mobile devices, this ScanSnap delivers a true "scan anytime scan anywhere.
The ScanSnap iX100 can automatically detect Wi-Fi networks at home, in the office or on the go, it is only needed to be set up once after which any regularly visited network environment will be automatically detected. Alternatively with Direct Connect mode it is possible to scan wirelessly beyond an infrastructure network, simply download the ScanSnap Connect Application free of charge from the official application distribution services and then scan, save and distribute documents directly to an iPad, iPhone or Android device.
A multitude of everyday documents can be seamlessly processed by the iX100 at a speedy 5 seconds, whether it be business cards or receipts (check out the impressive dual scan functionality that allows you to scan small documents simultaneously), photos, thicker items like postcards, bills, everyday A4 documents or even A3 documents. Scan both sides of a folded A3 document one after the other and if an adjoining pattern is detected the bundled software will automatically join the 2 page images together.
The iX100 will automatically detect and scan in black and white or color, will recognize the size of each document and scan accordingly, will detect and correct for skew and will show images in their proper orientation with blank pages removed. All these automatic functions help ensure that the first scan is the best scan and minimize operator involvement.
The iX100 can link to cloud services Dropbox, Evernote, Google Docs, Salesforce CRM and SharePoint Online (for Windows). It also brings some additional cloud syncing functions: Scan to SugarSync and Scan to Salesforce Chatter as well as ScanSnap folder for Win OS only where you can scan into your preferred cloud service when no scan interface is available through the import capability.
With the bundled ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents can be automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
The bundled ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
Fujitsu ScanSnap iX100 - sheetfed scanner
Sheetfed scanner - portable
Interface Type
USB 2.0, Wi-Fi
Scan Element Type
Contact Image Sensor (CIS)
Light Source
RGB LED array
Additional Functions
Scan to cloud, scan to smart devices
Max Supported Document Size
216 x 863 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Speed
5 sec / scan
Max Document Size
216 mm x 863 mm
Supported Document Type
Plain paper, business card, post card
Document Feeder Type
Manual
Lithium Ion
Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Apple MacOS X 10.7 - 10.12
27.3 cm x 4.75 cm x 3.6 cm
400 g
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0, Wi-Fi
216 x 863 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Element Type
Bulb / Light Source Type
RGB LED array
Scan Speed
5 sec / scan
Scanner Speed Details
5.2 sec/scan - A4 - 150 dpi , 5.2 sec/scan - A4 - 200 dpi , 5.2 sec/scan - A4 - 300 dpi , 20.4 sec/scan - A4 - 600 dpi
Scanner Features
Automatic colour detection, automatic page size detection, Blank Page Detection, A3 stitching, Continuous Document Feeding
Media Handling
Max Document Size
216 mm x 863 mm
Manual
USB 2.0
RoHS
Power Consumption Operational (Standby)
4.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
2.2 Watt
Battery Installed
Lithium Ion
720 mAh
Run Time (Up To)
260 pages
Software Included
ScanSnap Manager, CardMinder, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, ScanSnap Organizer, ScanSnap Receipt, ScanSnap Sync
27.3 cm
4.75 cm
3.6 cm
400 g
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
