BT.com
Wishlist
Fujitsu ScanSnap iX500 with Fujitsu RN31221D-100EUS 900GB NAS
Delivery
Standard Due date unavailable
The ScanSnap iX500 provides PC and Mac users an effective way to greatly reduce paper clutter, storage space, and security risk associated with unmanaged paperwork at home or office. For even greater accessibility and usefulness, users can scan wirelessly to a PC or Mac and now iOS or Android mobile devices.
The ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
With ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents are automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
Fujitsu ScanSnap iX500 - document scanner - desktop - USB 3.0, Wi-Fi - with NETGEAR ReadyNAS 312 RN31221D
Document scanner - desktop
Interface Type
USB 3.0, Wi-Fi
Scan Element Type
Dual CIS
Light Source
RGB LED array
Additional Functions
Email, scan to network share
Max Supported Document Size
216 x 863 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
25 ppm (mono) / 25 ppm (colour)
Max Document Size
216 mm x 863 mm
Automatic Duplexing
Supported Document Type
Plain paper, card scanner
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X 10.7 Lion, Windows 8, Apple MacOS X 10.8, Microsoft Windows XP 32-bit, Windows 10
29.2 cm x 15.9 cm x 16.8 cm
3 kg
Environmental Standards
ENERGY STAR Qualified
2 years warranty
Bundled with
Interface Type
USB 3.0, Wi-Fi
216 x 863 mm
Bundled with
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Dual CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
25 ppm
Scanner Speed Details
25 ppm - duplex - portrait - A4 - 150 dpi , 25 ppm - duplex - portrait - A4 - 200 dpi , 25 ppm - duplex - portrait - A4 - 300 dpi , 7 ppm - duplex - portrait - A4 - 600 dpi , 25 ppm - duplex - portrait B&W - A4 - 300 dpi , 25 ppm - duplex - portrait B&W - A4 - 400 dpi , 25 ppm - duplex - portrait B&W - A4 - 600 dpi , 7 ppm - duplex - portrait B&W - A4 - 1200 dpi
Scanner Features
One-Button function, Separation Sheet Detection, Ultrasonic multifeed sensor, Wi-Fi connection only for Android / iOS
Media Handling
Max Document Size
216 mm x 863 mm
Supported Document Size Details
ADF - up to 216 x 863 mm
Automatic
50 sheets
USB 3.0 - Type B
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
20 Watt
Software Included
ScanSnap Manager, CardMinder, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, ScanSnap Organizer, Adobe Acrobat DC (download)
29.2 cm
15.9 cm
16.8 cm
3 kg
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
