Click to visit BT.com
BT.com
Wishlist
Fujitsu Primergy TX300 S7 SFF XEON E5-2630 8GB Tower Server
Quicklinx: 835WWS00
Mfr#: VFY:T3007SC020IN
The PRIMERGY TX300 S7 is a no compromise tower server with maximum levels of performance, expandability and availability. It combines the performance of Intel Xeon processor. The expandability is excellent thanks to the 10 expansion slots and up to 24 2.5-inch hard disks. Thanks to the high availability offered by LAN card, redundant fans and up to 4 hot-plug power supplies, the TX300 S7 is suited to database, virtualization or high performance computing scenarios. Moreover, the TX300 S7 power supplies reach energy efficiency levels of 94%, minimizing running costs and the environmental impact.
Fujitsu PRIMERGY TX300 S7 - Xeon E5-2630 2.3 GHz - 8 GB - 0 GB
Server - tower
Server Scalability
2-way
1 x Intel Xeon E5-2630 / 2.3 GHz ( 2.8 GHz ) ( 6-core )
Processor Socket
LGA2011 Socket
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
8 GB (installed) / 768 GB (max) - DDR3 SDRAM - Advanced ECC - 1333 MHz - PC3-10600
Storage Controller
RAID ( SAS 6Gb/s ) ( LSISAS2108 ) ; SATA ( SATA 6Gb/s )
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD±RW (±R DL) / DVD-RAM
GigE
AC 120/230 V ( 50/60 Hz )
Power Redundancy
17.7 cm x 77.7 cm x 45.6 cm
Server
Product Form Factor
Tower
Server Scalability
2-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Max Turbo Speed
2.8 GHz
Number of Cores
6-core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011 Socket
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
8 GB / 768 GB (max)
Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
Hot-swappable, Memory Mirroring, quad channel memory architecture
Hard Drive
No HDD
Storage Controller
1 x RAID
Controller Interface Type
SAS 6Gb/s
Storage Controller Name
LSISAS2108
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
512 MB
Storage Controller (2nd)
1 x SATA - integrated
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S3)
Bays
8 (total) / 8 (free) x hot-swap 2.5" , 3 (total) / 2 (free) x external 5.25"
Slots
2 (total) / 1 (free) x CPU , 24 memory , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-height ( x4 mode ) , 4 PCIe 3.0 x8 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height ( x8 mode ) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-height ( x4 mode )
10 x USB 2.0 ( 2 front, 4 rear, 2 internal ) , 1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC) , 1 x serial
Redundant fans
FCC Class A certified, CSA, BSMI CNS 13438 Class A, GS, VCCI Class A ITE, CB, ICES-003 Class A, RoHS, WEEE, cULus
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
4
Nominal Voltage
Power Provided
800 Watt
Operating System / Software
Software
ServerView
17.7 cm
77.7 cm
45.6 cm
10 °C
35 °C
10 - 85% (non-condensing)
