BT.com
Wishlist
Fujitsu Primergy RX100S7 4 GB RAM 3.1 GHz
Delivery
Standard Due date unavailable
The Fujitsu PRIMERGY RX100 S7 is an entry mono socket rack server designed to meet small budgets by delivering highest energy efficiency of its class and a rich set of optional expansions to meet individual demands.
Fujitsu PRIMERGY RX100 S7p - Xeon E3-1220V2 3.1 GHz - 4 GB - 0 GB
Server - rack-mountable
Height (Rack Units)
1U
Server Scalability
1-way
1 x Intel Xeon E3-1220V2 / 3.1 GHz ( 3.5 GHz ) ( Quad-Core )
Processor Socket
LGA1155 Socket
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA ( SATA 3Gb/s )
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD±RW (±R DL) / DVD-RAM
GigE
AC 120/230 V ( 50/60 Hz )
48.3 cm x 57.2 cm x 4.3 cm
14 kg
1 year warranty - on-site
Server
Product Form Factor
Rack-mountable - 1U
Built-in Devices
Led panel
Server Scalability
1-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
2
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1155 Socket
Chipset Type
Intel C202
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800 (1600 MHz)
Unbuffered, dual channel memory architecture
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
5
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM - SATA
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD)
CD / DVD Rewrite Speed
16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel 82574L, Intel 82579LM
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S3)
Wake on LAN (WoL), PXE support
Bays
2 (total) / 2 (free) x hot-swap 3.5" , 1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line)
Slots
1 (total) / 0 (free) x CPU , 4 memory , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x4 - low-profile ( x1 mode ) , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile ( x4 mode )
6 x USB 2.0 ( 2 front, 4 rear ) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management - Ethernet 10Base-T/100Base-TX/1000Base-T
Rack mounting kit (full extraction), cable arm
No power cord is included
Asymmetrical design
FCC Class A certified, VCCI, C-Tick, BSMI, GOST, GS, CB, CCC, RoHS, WEEE, cULus, KC, cCSAus
Power supply
Nominal Voltage
Power Provided
300 Watt
Efficiency
90%
Operating System / Software
Software
ServerView
Limited warranty - 1 year - on-site
48.3 cm
57.2 cm
4.3 cm
14 kg
15 °C
35 °C
10 - 85% (non-condensing)
Sound Emission
24 dBA
Accessories
Fujitsu RAID Ctrl SAS 6G 0/1
Quicklinx: 718X | In Stock
£101.32
Scroll to top
