BT.com
Wishlist
Fujitsu fi-7160 Scanner with Fujitsu RN31441D-100EUS 2.7TB NAS
Delivery
Standard Due date unavailable
Both hardware and software are equally important in the Fujitsu fi-7160 scanner. The newly developed PaperStream IP driver and image processing middleware combined with the PaperStream Capture software offer simplified and automated batch scanning routines that intelligently convert batches of documents into predetermined work routines.
This new fi series model offers USB 3.0 support and is designed to make end-to-end scanning processes faster. The fi-7160 model processes up to 60 sheets/120 pages per minute (A4, color, duplex, 300 dpi). Additional functions also help deliver top results. For example, it is easy to scan a mixed batch containing sheets of different sizes and thicknesses. The scanner mechanically straightens any documents that may have been fed askew and PaperStream IP also automatically corrects any remaining irregularities. An ultrasonic sensor recognizes whether two or more sheets have fed in and issues an error message. Even sticky notes do not delay the workflow as the system recognizes them automatically. Further, user support is provided through the scanners' LCD panel which provides straightforward operation flows and allows users to select profiles directly on the device, check the quantity of scanned documents or review any status messages.
Fujitsu fi-7160 - document scanner - desktop - USB 3.0 - with NETGEAR ReadyNAS 314 RN31441D
Document scanner - desktop
Interface Type
USB 3.0
Scan Element Type
Dual CCD
Max Supported Document Size
216 x 355.6 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
216 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
4000 scans per day
Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
30 cm x 17 cm x 16.3 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
Bundled with
Interface Type
USB 3.0
216 x 355.6 mm
Bundled with
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Dual CCD
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
4000 scans per day
Scanner Speed Details
60 ppm - colour - 200 dpi , 60 ppm - colour - 300 dpi , 60 ppm - greyscale - 200 dpi , 60 ppm - greyscale - 300 dpi , 60 ppm - black & white - 200 dpi , 60 ppm - black & white - 300 dpi , 120 ipm - duplex - colour - 200 dpi , 120 ipm - duplex - colour - 300 dpi , 120 ipm - duplex - greyscale - 200 dpi , 120 ipm - duplex - greyscale - 300 dpi , 120 ipm - duplex - black & white - 200 dpi , 120 ipm - duplex - black & white - 300 dpi
Scanner Features
Built-in LCD screen
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 5588 mm
Plain paper
Automatic
80 sheets
USB 3.0 - Type B
RoHS
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
38 Watt
Software Included
Scanner Central Admin, PaperStream IP, PaperStream Capture
30 cm
17 cm
16.3 cm
4.2 kg
5 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
