BT.com
Wishlist
Fujitsu fi-6400 Scanner with Fujitsu RN31661E-100EUS 4.5TB NAS
Fujitsu fi-6400 Scanner with...
£7,203.12
£7,203.12
Add to wishlist
Delivery
Standard Due date unavailable
With improving the entire scanning process as its main objective, the fi-6400 production scanner builds upon the qualities that have made Fujitsu the optimal vendor in the mid-volume production market. The fi-6400 incorporates many additional features and functions that will improve your document scanning efficiency. From pure scanning speed, to ease of use to its full suite of software productivity tools, the fi-6400 is the ideal solution for a wide range of production scanning applications.
Fujitsu fi-6400 - document scanner - with NETGEAR ReadyNAS 316 RN31661E
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Light Source
White LED array
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
100 ppm (mono) / 100 ppm (colour)
Max Document Size
297 mm x 420 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
500 sheets
Duty Cycle
40000 scans per day
AC 120/230 V
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Windows 8.1
46 cm x 43 cm x 31 cm
32 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Bundled with
Interface Type
USB 2.0
A3 (297 x 420 mm)
Bundled with
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
Dual CCD
Bulb / Light Source Type
White LED array
Max Document Scan Speed B/W
100 ppm
Max Document Scan Speed Colour
100 ppm
Duty Cycle
40000 scans per day
Scanner Speed Details
100 ppm - landscape - A4 - 200 dpi , 100 ppm - landscape - A4 - 300 dpi , 200 ipm - duplex - landscape - A4 - 200 dpi , 200 ipm - duplex - landscape - A4 - 300 dpi , 85 ppm - portrait - A4 - 200 dpi , 85 ppm - portrait - A4 - 300 dpi , 170 ipm - duplex - portrait - A4 - 200 dpi , 170 ipm - duplex - portrait - A4 - 300 dpi
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection, Intelligent Multi-Feed Function (iMFF), Paper Protection Function, Image Emphasis, Automatic Image Orientation, Error Diffusion, automatic colour detection, automatic page size detection, upper lower separation, blank page skipping, Dither, Simplified DTC, Advanced DTC, Multi-Image Output, built-in LCD screen, Remove Background, Deskew, Long Document Scanning, Background Color Switching
TWAIN, ISIS
Media Handling
Max Document Size
297 mm x 420 mm
Plain paper
Supported Document Size Details
Long document - up to 297 x 3048 mm
Automatic
500 sheets
USB 2.0 - Type B
1 x USB cable
Directive 2009/125/EC, RoHS 2011/65/EU
ENERGY STAR Certified
External power adapter
AC 120/230 V
Power Consumption Operational (Standby)
200 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
3.2 Watt
Software Included
Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
46 cm
43 cm
31 cm
32 kg
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
15 °C
35 °C
20 - 80% (non-condensing)
Scroll to top
