BT.com
Wishlist
Fujitsu fi-6110 Document Scanner
Delivery
Standard Due date unavailable
The Fujitsu fi-6110 scanner's small footprint and advanced feature set make it an ideal solution for decentralized scanning environments. With its true, 600-dpi optical resolution and dual- CCD cameras, it captures your documents' finest details in color, grayscale, and monochrome. What's more, it shares much of the advanced technology found in higher-end scanners, including a 50-sheet automatic document feeder (ADF) that accommodates a wide range of document sizes, ultrasonic double-feed detection for greater security, and a Carrier Sheet function for feeding fragile or oversized (A3) documents. Plus at speeds up to 20 ppm (simplex) / 40 ipm (duplex) it quickly and efficiently transforms your paper documents into more manageable digital files.
Fujitsu fi-6110 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Max Supported Document Size
Legal (216 x 356 mm)
Input Type
Grayscale / Color Depth
10-bit grey
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
20 ppm (mono) / 20 ppm (colour)
Max Document Size
216 mm x 3048 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
2000 scans per day
AC 120/230 V
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
29.2 cm x 14.3 cm x 13 cm
3 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth
10-bit grey
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Dual CCD
Max Document Scan Speed B/W
20 ppm
Max Document Scan Speed Colour
20 ppm
Duty Cycle
2000 scans per day
Scanner Speed Details
20 ppm - black & white - A4 - 200 dpi , 20 ppm - colour - A4 - 300 dpi , 40 ipm - duplex - black & white - A4 - 200 dpi , 40 ipm - duplex - colour - A4 - 300 dpi
Scanner Features
Color Dropout, Image Emphasis, Error Diffusion, Ultrasonic multifeed sensor, automatic colour detection, automatic page size detection, upper lower separation, blank page skipping, Moire Removal, Dither, Simplified DTC, Advanced DTC, Multi-Image Output
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 3048 mm
Plain paper
Automatic
50 sheets
USB 2.0 - Type B
1 x USB cable
RoHS
ENERGY STAR Certified
External power adapter
AC 120/230 V
Power Consumption Operational (Standby)
28 Watt (5.36 Watt)
Software Included
ScanSnap Manager, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
29.2 cm
14.3 cm
13 cm
3 kg
5 °C
35 °C
20 - 80%
Scroll to top
