BT.com
Wishlist
Fujitsu FI-5530C2 Duplex Document Scanner with Paperstream
Delivery
Standard Due date unavailable
The Fujitsu fi-5530C2 color A3 departmental scanner offers an incredible feature set in a compact package. It features dual color CCDs with true, 600-dpi resolution for capturing subtle details, and uses ultrasonic double-feed detection for reliable, automatic scanning. For simplified connectivity the Fujitsu fi-5530C2 features a dual-interface, including ports for SCSI and USB 2.0 connections. The fi-5530C2 is bundled with PaperStream IP and PaperStream Capture.
Fujitsu fi-5530C2 - document scanner - desktop - USB 2.0, SCSI
Document scanner - desktop
Interface Type
USB 2.0, SCSI
Scan Element Type
CCD
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth
10-bit grey
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
35 ppm (mono) / 35 ppm (colour)
Max Document Size
297 mm x 863 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
100 sheets
Duty Cycle
2500 scans per day
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
39.9 cm x 22.5 cm x 19.3 cm
8.5 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0, SCSI
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth
10-bit grey
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
CCD
Max Document Scan Speed B/W
35 ppm
Max Document Scan Speed Colour
35 ppm
Duty Cycle
2500 scans per day
Scanner Speed Details
35 ppm - black & white , 35 ppm - colour , 70 ipm - duplex - black & white , 70 ipm - duplex - colour
TWAIN, ISIS
Media Handling
Max Document Size
297 mm x 863 mm
Plain paper
Automatic
100 sheets
USB 2.0 - Type B , Ultra SCSI
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
57 Watt (7.5 Watt)
Software Included
ScanSnap Manager, Scanner Central Admin, Software Operation Panel, PaperStream IP, PaperStream Capture
39.9 cm
22.5 cm
19.3 cm
8.5 kg
5 °C
35 °C
20 - 80%
Scroll to top
