BT.com
Wishlist
Fujitsu DX100 S3 Base Encl 2.5 INCH (CE) Cntrl. X1
Delivery
Standard 1-3 working days
Combining leading performance architecture with automated quality of service management the Fujitsu Storage ETERNUS DX series aligns storage resources with business priorities, thus enabling higher system utilization and delivering increased system consolidation capabilities and a faster ROI.
The scalable and unified Fujitsu Storage ETERNUS DX100 S3 delivers enterprise-class functionality to small and medium-sized companies and subsidiaries with an excellent price/performance ratio. It is the perfect solution when consolidating data for server virtualization, e-mail, databases and business applications as well as centralized file services. Simple, intuitive system management, highly flexible network connectivity and the option of field upgrades to higher system classes significantly reduce operational and migration costs. The ETERNUS DX family architecture lets customers benefit from software options, such as thin provisioning, automatic storage tiering and quality of service management even as early as the entry-level class. This all contributes to better business support.
Fujitsu ETERNUS DX 100 S3 Controller Enclosure - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
24 (max)
Supported Drives
SAS-3
Hard Drive
0 - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
48.2 cm x 64.5 cm x 8.8 cm
35 kg
3 years warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
Supported Devices / Modules Qty
24
Supported Drives
SAS-3
Hard Drive
Hot-swap
0
Expansion Bays
24 (total) / 24 (free) x hot-swap - 2.5"
92% efficiency power supply
VCCI, C-Tick, CISPR 22 Class A, GOST, GS, EN55024, EN55022 Class A, CB, ICES-003 Class A, FCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FCC CFR47, GOST-R, CSA C22.2 No. 60950-1, Directive 2004/108/EC, Directive 2006/95/EC, VCCI Class A, Directive 2011/65/EC, AS/NZS CISPR 22, CNS 13438
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
48.2 cm
64.5 cm
8.8 cm
35 kg
Limited warranty - 3 years - on-site
10 °C
20 - 80% (non-condensing)
Sound Emission
49 dBA
Scroll to top
