BT.com
Wishlist
Fujitsu Business Critical Hard Drive 1TB SATA 6Gb/s
Fujitsu Business Critical Hard...
£113.59
£113.59
Add to wishlist
Delivery
Standard 1-3 working days
1 TB Hard Disk Drive (Seagate ST1000NM0033), Serial ATA 300 6 Gb/s interface, 7200 rpm, 128 MB cache buffer, 512N, 3.5-inch drive form factor, supplied in hot plug frame
Fujitsu Business Critical - hard drive - 1 TB - SATA 6Gb/s
Hard drive - hot-swap
1 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Advanced format 512n
PRIMERGY RX2510 M2 (3.5"), RX2530 M2 (3.5"), RX2540 M2 (3.5"), RX2540 M2 Storage Spaces (3.5"), TX1330 M2 (3.5"), TX2560 M2 (2.5")
1 TB
3.5" LFF
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
512
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" LFF
Hot-plug tray
Fujitsu PRIMERGY RX2510 M2 (3.5"), RX2530 M2 (3.5"), RX2540 M2 (3.5"), RX2540 M2 Storage Spaces (3.5"), TX1330 M2 (3.5"), TX2560 M2 (2.5")
Scroll to top
