BT.com
Wishlist
Fujitsu B22T-7 Pro 21.5" 1920x1080 5ms VGA DVI HDMI LED Monitor
Delivery
Standard Due date unavailable
The B22T-7 Pro is a great choice for intensive office work. Wide viewing angle technology and excellent ergonomics enable fatigue-free working for hours in front of the screen. With 21.5" it needs only little space and reliably works around the clock. Easy connectivity and usability help you to increase your productivity.
What's in the box
  • Fujitsu B22T-7 pro
  • DVI cable - 1.8 m
  • Audio cable - 1.8 m
  • USB cable - 1.8 m
  • Stand
Fujitsu B22T-7 pro - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
17 W
USB Hub
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
10 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Matte black
51.6 cm x 20.4 cm x 33.9 cm
5.9 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, BSMI, GOST, cUL, EN 60950, SASO, TUV S, CCC, DDC/CI, RoHS, ISO 9241-307, WEEE, S Mark, KC, Directive 2004/108/EEC, TCO Displays 6.0, RCM, VESA MIS-D 100 C
Display Type
Energy Class
Class A
24 kWh
17 W
Diagonal Size
21.5"
Built-in Devices
USB Hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 6500K, 7500K
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, input select, colour temperature, phase, clock, black level
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
sRGB colour management, HDCP, ECO button, DisplayView, WideView, Low Blue Light Mode
Matte black
51.6 cm x 20.4 cm x 33.9 cm - with stand
5.9 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
VGA , DVI-D , HDMI , Audio line-out , Audio line-in , 4 x USB 2.0 downstream , USB upstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Flicker-free technology
Stand
1 x DVI cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
MTBF
70,000 hour(s)
United Kingdom
22 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.2 Watt
Dimensions & Weight Details
With stand - width: 51.6 cm - depth: 20.4 cm - height: 33.9 cm - weight: 5.9 kg , Without stand - width: 51.6 cm - depth: 6.28 cm - height: 31.6 cm - weight: 3.3 kg
ENERGY STAR Certified
5 °C
35 °C
Scroll to top
